V-Cap's...any opinions.
pearsall001
pearsall001 Posts: 5,325
edited November 2010 in Electronics
Anyone have any experience with using V-Caps, in particular their flagship CuTF, the TFTF or the OIMP. In your opinion how do they compare to other brands musically. Also, what other brands would you recommend to take a look at. I'm looking to replace the 4 stock caps in my Music Hall dac25.2 unit.
Post edited by pearsall001 on
  • Face
    Face Posts: 14,340
    I've used Sonic Cap Platinums, which are very similar to the TFTF. Expect more transparency, dynamics, and lack of coloration. But, in some rigs there can be a touch of dryness or sterility. Supposedly the CuTF is a little warmer and is what I would have used if they were available then.
    But then again, another option is the Claritycap MR. Smaller values are now being made and should be available soon.
    How would you describe the sound of your rig now and how are you looking to change it?
  • pearsall001
    Face wrote: »
    Now that I've sold my AAD's & have the LSi15's I'd say the sound is a tad more on the mellow side. It's a new musical presentation that I really am enjoying. My basis on replacing the stock caps is due to the fact that manufactures design their products to meet a certain price point. After replacing the stock tube with an Amperex Bugle Boy tube & replacing the stock op-amps with Burson HD op-amps the difference I am now hearing is not subtle to say the least.
    So the next logical step is to replace the stock output caps. It just keeps getting better & better & is a lot of fun seeing & hearing these changes. I'm open for all cap referrals & how they effect the sound moving forward.
  • Face
    Face Posts: 14,340
    Standard V-caps would definitely liven things up. I would wait a little bit longer for Clarity MR's though. Do you know what values you need?
  • dkg999
    dkg999 Posts: 5,647
    I recently acquired the Music Hall DAC 25.3. Upgrading to a NOS Mullard 6922 made a big improvement in SQ. I've got some NOS Amperex and new Gold Lion 6922's to also try. In an email exchange with Roy Hall he recommended the EAT 6922 and said that was what he uses, but I thought I would try some cheaper alternatives.
    It looks like the Burson op-amp is a plug & play replacement, which one did you use? Also I see references to the need to upgrade the power supply diodes and caps to drive the full benefit of the Burson op-amp upgrade, did you also do that?
    DKG999
  • pearsall001
    Face wrote: »
    By standard do you mean the OIMP version or the TFTF version. If my memory serves me the value I need is 1.5. It looks like you really like the Clarity MR's, what do they do differently from the others?
    dkg999 wrote: »
    I went with an Amperex Bugle Boy tube that really opened things up. I also thought about the EAT 6922 but it's pretty pricey. Maybe down the road I'll give it a shot. I did the Burson HD plug & play op-amps. They really made a difference. For now I haven't done anything with the power supply as far as mods go.
  • dkg999
    dkg999 Posts: 5,647
    Thanks! So far I'm really impressed with the MH DAC. It didn't win out over my PS Audio DLIII in the main system with my Magnepan 1.6's, but it came pretty close.
    DKG999
  • Face
    Face Posts: 14,340
    I was referring to the TFTF version, I have no experience with the OIMP version.
    As for the MR's, they just do everything right IMO.
  • pearsall001
    dkg999 wrote: »
    If all you did so far was to swap out the tube...you haven't heard nothing yet!! It just keeps getting better.
    Face wrote: »
    Thanks, that's what I thought. I'll have to check out the MR's & also the CuTF V-Cap, they seem to be held in high regard.
  • george daniel
    george daniel Posts: 12,096
    I have the V cap OIMP in my Wright pre(output coupling caps)They really added some nice warmth/richness to the mids,,while really smoothing out the highs,,certainly improved the top end,and made my overall listening experience much more pleasant,,IIRC,Chris suggests about a 96 hour minimum burn in,and a specific "direction".
