1 RCA Male to 2 RCA Male Cable
Feferefe
Hi:
Can someone know where to get a 1 Male RCA to 2 Male RCA Cable. I dont want to use adapters if possible. This is for split one channel in two.
Thanks,
Thanks,
Post edited by Feferefe on
what length ?
www.RadioShack.com
www.parts-express.com
amazon.com
http://www.amazon.com/Cables-Go-03161-Stereo-Y-Cable/dp/B0002J1KVM/ref=sr_1_34?ie=UTF8&qid=1290543412&sr=8-34
Cables To Go 03161 Value Series One RCA Mono Male to Two RCA Stereo Male Y-Cable (6 Inch) Black -
Thanks JVC for your prompt response. The CableToGo cable is an adapter, and I'm trying to stay away from that. What I need is a cable about 1 feet long that start at 1 male and end in 2 male with no interconnections. I thinking in buying this ones. This will be plugged in the amp input where the interconnect from the pre-amp will end. The a second interconnect from the spare female to the other input channel. What do you think? Or do you think I better go with an Y adapter?
Thanks, -
That is the first time I've seen monster adapters like that.
It's nice and looks solidly built. Gold plated.
if you use these you'll need to still get (2) 1 foot cables RCA male - RCA male .
by the way
What exactly are you trying to connect?
perhaps you could modify the mono end . single RCA male side ?
got pictures of the gear ?
