More Newbie SDA Tweeter Questions
Jiminypage
Jiminypage Posts: 19
edited December 2010 in Vintage Speakers
YO...my new-to-me SDA IIs came with one blown tweet and one that was distorting. I swapped out some tweeters from Polks 7's that I had around. One appears to be the new RD0194. The other appears to be the Sl 2000. So what I have now is the original sl 1000s in the stereo position on both speakers, a 2000 in one SDA position and a 194 in the other SDA position.
They sound amazing, but I'm not happy with this mix match.
So the question is, what to do next? Should I by a pair of 1000s to replace the two bad original tweets (and have them all 1000s) OR buy one new 194 so that the stereo tweets and SDA tweets match OR just buy four new 194s and replace them all? Possibly there is another option that I haven't thought of.
A followup question is, are the 194s a straight drop in replacement for the 1000s? They look to be a slightly different size/shape.
Thanks VERY much for any advice!
Upstairs Rig
Luxman R 117 Reciever
Denon CD Player
Denon DP 45-F Turntable/ Denon 103 Cart
Polk SDA 1C Speakers
Mancave Rig
Carver TFM-35x Amp
Marantz 2252B used as Preamp
Pro-Ject 1.2 Turntable/Sumiko Pearl Cart
Pioneer Elite CD Player/Recorder
Polk SDA II Speakers
Post edited by Jiminypage on
  • Joe08867
    Joe08867 Posts: 3,919
    edited November 2010
    Yo... I like that. Anyway, I would replace them with the RDO-194. But I would only replace the Stereo Tweeter not the dimensional. It should be drop in as it was in mine. I have the same model speaker as you. I replaced all of my tweeters and later tried without the dimensional and have not looked back. They are totally better sounding without the dimensional tweeter.
    For a bit of history. In the later versions of these speakers SDAII Polk eliminated that tweeter as it added to much ting to the sound and made them tiresome to listen to for extended periods.
    If you don't feel comfortable with the new tweeter I would suggest the SL2000 as better sounding overall.
  • brgman
    brgman Posts: 2,859
    The dimensional is the outside tweet right?
    I’M OFFENDED!!!!
  • Joe08867
    Yes outside is dimensional.
  • Jiminypage
    Hey thanks Joe...very helpful. I will give that a try.
    Upstairs Rig
    Denon CD Player
    Mancave Rig
    Carver TFM-35x Amp
  • Joe08867
    Let us know how it turns out.
  • Jiminypage
    OK...first update is that I took your advice and disabled the two dimensional tweeters (but left them in place which I assumed was needed to keep the hole plugged). I agree this sounds terrific and interestingly enough the dimensional effect doesn't seem to suffer. So, currently, there are two mismatched tweeters in the regular tweeter positions (a 1000 and a 2000).
    I ordered and recieved two new 194s from Polk to replace the 1000 and 2000, but noticed that the screw positions are slightly different (they are spaced slightly wider with the 194s). Any suggestions on how to handle this? I'm sure it has been done before...
    Thanks in advance!
    Upstairs Rig
    Denon CD Player
    Mancave Rig
    Carver TFM-35x Amp
    Toolfan66 Posts: 18,187
    How did you get the first 194 to fit??
  • Jiminypage
    EXCELLENT question Tool. You've been paying attention. What I did was take the 194 tweeter out of mounting plate and put it in one of the bad 1000 mounting plates. Since these are brand new I was hoping not to do that this time.
    Thanks again!
    Upstairs Rig
    Denon CD Player
    Mancave Rig
    Carver TFM-35x Amp
  • ben62670
    ben62670 Posts: 15,969
    The mounting plate of the SL1000 fit the RDO tweeter? Please post pics.
    Ben
    Ben
  • Jiminypage
    I must say...this is a sharp group! Another great question. The RDO didn't fit perfectly into the 1000 mounting plate, but it fit. One of those deals where three screws go in but you have to angle the fourth a bit. I'm fussy enough that I wouldn't have done it if it was too sloppy. I'll post some picks. I'm starting to think the easiest thing to do would be fill the existing holes and drill out new ones to match the new RDOs....
    Upstairs Rig
    Denon CD Player
    Mancave Rig
    Carver TFM-35x Amp
  • Jiminypage
    So the job was a little easier than expected although I may not have done it perfectly. After taking out the old tweeters, I simply installed the new 194s over top of the shallow routed hole for the old tweeters. Two screws went into new wood and grabbed fine. I used to longer screws to get them to grab in the two old holes. They are secure and sound great. I suppose the perfectionist would have opened up the routing for the old tweeters to make the new tweets flush, but that would have been a lot more work and I'm not sure there would have been an audible benefit. Once the covers are back on, obviously no visual impact. Thoughts?
    Upstairs Rig
    Denon CD Player
    Mancave Rig
    Carver TFM-35x Amp
