In need of experienced help
Webb_03
Webb_03 Posts: 42
edited November 2010 in Speakers
I am thinking of upgrading my home theatre system, Im currently running a Cerwin Vega 5.1, my amp is a carver av 705x, Carver processor, E-712 300W main CV's with 2 bookshelfs and center channel with a 10 in CV sub.
Hence id like to upgrade to some Polk Audio, my price range is mostly With either the TSi series or The older Moniter series, Moniter 70 etc, So my Question is Am i better off going with the TSi series or the older Moniter series?
Any help would be much appreciated. - Chris
B&W CM10 Mains, Monitor 40 Surrounds, B&W Cm Centre, PSW 125 sub/ CV 10" sub, Marantz 7701 Processor, Carver M4.0T, Carver 705x 5 channel, 60'' Sharp LED, Xbox One, Xbox 360, Sonos, and of course my trusty laptop for hi res ( for now)
Post edited by Webb_03 on
  • PrazVT
    PrazVT Posts: 1,607
    I think Monitor 70 Series II are very well regarded on here (see newegg). Good bang for the buck ..you could get CS2/CS20, Monitor 40s, psw-505 sub and just scratch the $1000 mark.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
  • Webb_03
    Webb_03 Posts: 42
    PrazVT wrote: »
    So you think the moniter series is a better speaker or just a better bang for the buck? I am limited on funds but im trying to build a system that will sounds Good with Movies and music, and dont wanna do it too cheap because i probly wont have a chance to upgrade again for a long time.
  • TECHNOKID
    TECHNOKID Posts: 4,298
    Webb_03 wrote: »
    Monitor 70 are definitely your best bang for the buck at this point. Check for the sales if you are not in a hurry :wink:
    Oh BTW, welcome to Club Polk:)
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
  • Webb_03
    Webb_03 Posts: 42
    TECHNOKID wrote: »
    Okay ill probly go with the monitor series then i guess? over the tsi? Any more opinions before i pull the trigger?
  • Ericw2431
    Ericw2431 Posts: 228
    Go for it!=]
    Room Theater:
    Fronts:RTIA3
    center; CSIA6
    AVR: Onkyo 709
    panasonic 55"plasma
    Ps3 slim 250gb
    surrounds.Fxia6
    Sub...svs pc13 ULTRA
    Amp:Emotiva xpa3
