In need of experienced help
I am thinking of upgrading my home theatre system, Im currently running a Cerwin Vega 5.1, my amp is a carver av 705x, Carver processor, E-712 300W main CV's with 2 bookshelfs and center channel with a 10 in CV sub.
Hence id like to upgrade to some Polk Audio, my price range is mostly With either the TSi series or The older Moniter series, Moniter 70 etc, So my Question is Am i better off going with the TSi series or the older Moniter series?
Any help would be much appreciated. - Chris
B&W CM10 Mains, Monitor 40 Surrounds, B&W Cm Centre, PSW 125 sub/ CV 10" sub, Marantz 7701 Processor, Carver M4.0T, Carver 705x 5 channel, 60'' Sharp LED, Xbox One, Xbox 360, Sonos, and of course my trusty laptop for hi res ( for now)
Post edited by Webb_03 on
I think Monitor 70 Series II are very well regarded on here (see newegg). Good bang for the buck ..you could get CS2/CS20, Monitor 40s, psw-505 sub and just scratch the $1000 mark.Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
..the rest are headphone setups. -
So you think the moniter series is a better speaker or just a better bang for the buck? I am limited on funds but im trying to build a system that will sounds Good with Movies and music, and dont wanna do it too cheap because i probly wont have a chance to upgrade again for a long time.B&W CM10 Mains, Monitor 40 Surrounds, B&W Cm Centre, PSW 125 sub/ CV 10" sub, Marantz 7701 Processor, Carver M4.0T, Carver 705x 5 channel, 60'' Sharp LED, Xbox One, Xbox 360, Sonos, and of course my trusty laptop for hi res ( for now) -
Monitor 70 are definitely your best bang for the buck at this point. Check for the sales if you are not in a hurryI am thinking of upgrading my home theatre system, Im currently running a Cerwin Vega 5.1, my amp is a carver av 705x, Carver processor, E-712 300W main CV's with 2 bookshelfs and center channel with a 10 in CV sub.
Oh BTW, welcome to Club Polk:)DARE TO SOAR:
Okay ill probly go with the monitor series then i guess? over the tsi? Any more opinions before i pull the trigger?B&W CM10 Mains, Monitor 40 Surrounds, B&W Cm Centre, PSW 125 sub/ CV 10" sub, Marantz 7701 Processor, Carver M4.0T, Carver 705x 5 channel, 60'' Sharp LED, Xbox One, Xbox 360, Sonos, and of course my trusty laptop for hi res ( for now) -
Go for it!=]Room Theater:
Fronts:RTIA3
center; CSIA6
AVR: Onkyo 709
panasonic 55"plasma
Ps3 slim 250gb
surrounds.Fxia6
Sub...svs pc13 ULTRA
Amp:Emotiva xpa3
