Help identify this tweeter?
rad_ken1
rad_ken1 Posts: 9
edited November 2010 in Speakers
I've got a few sets of these tweeters but have no information on them. There are no logos or markings I can see on the front or rear. I believe they should be oem replacements for some production speakers maybe from late 1990's. Can anyone help with more info?
Post edited by rad_ken1 on
  • DaveHo
    DaveHo Posts: 3,582
    Pics of the back? With that heatsink, it kind of reminds me of a Paradigm tweet.
    -Dave
  • rad_ken1
    rad_ken1 Posts: 9
  • steveinaz
    steveinaz Posts: 19,545
    Possibly an early "Energy" speaker model. They usually have the defraction plate like those.
  • halo71
    halo71 Posts: 4,637
    yeah...dumb question time again. Is that really a heat sink on the back?
    --Gary--
  • dorokusai
    dorokusai Posts: 25,576
    halo71 wrote: »
    Absolutely.
  • FTGV
    FTGV Posts: 3,650
    I'm thinking they are Boston Acoustics VR series?
  • dorokusai
    I'm going with BA as well.
  • halo71
    halo71 Posts: 4,637
    dorokusai wrote: »
    Absolutely.
    Told ya it was a dumb question! :tongue:
    --Gary--
    nooshinjohn Posts: 25,963
    are there any markings under the heat-sink?
  • dorokusai
    halo71 wrote: »
    Not a dumb question. I've thought the same thing in regards to computer motherboard components(non-processor) as in, how on earth could that thing get so hot? It's so small! It's the overall architecture and usage that creates the heat. I never knew it that way.
    In a tweeter diaphragm, it moves so fast, so many times in a nanosecond that it generates heat. Even if it's a small amount, to a delicate structure such as a tweeter, this is an important factor. This will vary widely in construction in modern and vintage tweeters so not every design would require such a heatsink. That's what is so interesting about audio, is the overall design that these engineers figure out. Amazing.
  • FTGV
    FTGV Posts: 3,650
    dorokusai wrote: »
    It's the current flowing through the voicecoil that produces the heat not the movement.Anywho with some of the modern tweets utilizing smaller(but more powerful)neodymium magnets in their motor structures means there is less surface area for heat disipation vs tweets using the large ferrite magnet structures.So the addition of the heat sink helps in that regard.Here is another example,a popular budget unit from Vifa. http://www.madisound.com/store/product_info.php?products_id=8352
  • dorokusai
    That's correct as well....we're talking about the same thing essentially. If you didn't have current, you wouldn't have movement of the voice coil or structure at all. Anyways, good link and post.
