Adcom Remote
salasg
Anyone have a remote for Adcom GTP 500 pre.
Post edited by salasg on
There's one on ebay right now for ~$40.
I need one too but I don't feel like spending that much.
A universal would likely work. I know my B&K remote turns the GTP on and off no matter what button I hit.
Sounds good to me... -
Yeah saw that but didnt want to spend that much either.:biggrin: Will see if I can find universal for less. Thanks
If either of you guys could use a remote from a GTP450, I have one that works... but not on my GTP450... that's fried, as far as I can tell :frown:
PM or email me if you're interested, I can probably let the thing go for $50 shipped? Fix up the 450 and sell it off for a C-note, the thing is in excellent shape otherwise. And no, I have no idea why it won't power up anymore.So, are you willing to put forth a little effort or are you happy sitting in your skeptical poo pile?
http://audiomilitia.proboards.com/ -
Hey guys, hope I'm not stepping on any toes, but Adcom coded their remotes to be unit specific. The 450 remote will only work on the 450. I found out the hard way, picked up a 500 remote for my 450, no go. I sold the 500 remote a couple months ago.
Keep your eyes on ebay, be patient, you will probably be able to pick one up in $20 range.
Good luck. -
Damn, I had no clue about that.
(no wonder I didn't get a reply :rolleyes:
Thanks for the heads-up.So, are you willing to put forth a little effort or are you happy sitting in your skeptical poo pile?
Unit specific is not entirely true! My GFP-715 and 750 preamps work with both units remotes. In fact the GFP-715 comes with a 710 remote. You may want to call Adcom or check Adcom Direct remotes for compatability. -
