Change of plans on DACs. I am going to build one...
  • bikerboy
    bikerboy Posts: 1,246
    edited November 2010
    30 min to go to order the BuffaloII!!!!!!!!!!!!! Good Luck.
    Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w ONN Streamer, Sangean HDT-1X tuner
    Vinyl: Nottingham Spacedeck->Pioneer PL L1000 linear arm->Soundsmith DL 103R w Contact line stylus->SUT->
    Bottlehead Eros tube phono preamp
    CD: DIY Shigaclone
  • FTGV
    FTGV Posts: 3,650
    ben62670 wrote: »
    The reason I chose those boards is the DAC chips are the most popular with modders to get great results. The analog/PS stages is where most DACs fall short.
    Ben
    Agreed, about a year ago I purchased a kit similar to the one in your first link for my PC rig but it utulized the Crystal CS4397 DAC.It needed a few changes,one so it would accept data above 48k the other to correct the wrong component values in the LPF which resulted in a HF roll off starting at 13k.:eek:With these changes and the elimination of some coupling caps,exchanging the stock opamp and installing a discrete headphone driver stage has IME resulted in a great sounding unit for less than $100.After a year of use I still don't feel the need to upgrade.
    As for the Ultra Analog AE21 it is merely a select grade of CS8412 with a pair of PLL circuits for improved jitter rejection in a potted module.
  • bikerboy
    Greg,
    Were you able to get one? Looks like they sold out in less than 10 minutes!
    CD: DIY Shigaclone
  • headrott
    headrott Posts: 5,496
    Yep, I scored one.:biggrin: Yes, they were gone in 6 minutes!! Amazing. Either that shows you how good they are or how crazy some people are about thinking they are that good. Hopefully the former.
    Greg
  • ben62670
    ben62670 Posts: 15,969
    Fred one of the advantages of using tubes for DACs is the need for filters isn't there anymore. The tubes take care of that. All that is needed is a DC blocking cap on the outs.
    Ben
  • bikerboy
    Good job! What ps are you going with? I have a Mux, placids, legato and the soon to arrive trident regs. What will you use as a transport?
    CD: DIY Shigaclone
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    Ricardo offered to swap DACs with me a while back and like a dummy I did not take him up on it. I know Ricardo loves his but he also has a tube Pre. I am hoping to find a affordable to me DAC with a tube output stage because I have a SS integrated.
    I think I need a tube in the path to give me the sound I am looking for. Actually if I could find something that sounded as good as a Jolida JD100 I think I would be happy for a while.
    Sorry for the threadjack.
    Scott
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • ben62670
    Build one MLS. I have seen your work and I know you can do a bang up job of it. Feel free to call me if you like.
    Ben
    Ben
  • headrott
    bikerboy wrote: »
    I will be using a Denon DCD-3000 player, a Denon DVD-5910 or my AMC CD6b-5404as. I will probably tru all 3 and see what gives the best results.
    I have also aquired some tube output PCB's that I will be using as the I/V stage. I have read from others using the Buffalo II that it works out well and sounds fantastic. I can't wait to get all the parts and start building.
    Greg
  • TrashyTrucker
    TrashyTrucker Posts: 225
    Greg,
    I grasp what you guys are discussing and this is out of my league for now. :redface: Therefore I cannot give any opinions, but I do appreciate the good read(s). Nice thread and GLW the build!
    Pics or it didnt happen...LOL
    Matt :biggrin:
    Integra DTR 50.2 used as a preamp
    Rotel RCD 1520 cdp
    AudioQuest Jaguar 72v dbs ic's
    AudioQuest type 8 wire
    biamped to:
    2-Hafler 9500 trans nova's
    AudioQuest NRG-3 power cable's
    dedicated AC line for
    Tesla Plex 20a duplex receptacle
    Panamax Max 7500 pro surge/line conditioner
    SDA SRS 3.1 TL's modded...
    spikes, rdo's, rings, dynamat, sonicaps, mills & aeon
    Panasonic Viera G20 50" plasma
    ...SDA's are just like candy for your ears...
  • ben62670
    Do you have a link for the tube output PCB's?
    Ben
    Ben
  • headrott
    Sure do Ben. I will be using 2 of them to have balanced output. Here they are from the DIYAudio forum sourced froma guy in Germany. He basically took the Lampizator idea and put it on a PCB, but also added switch to adjust the voltage to the tube heaters so you can try different tubes in it (them). That's the main reason I got it was for the ease of multi tube capability. I also got this B+ shunt PCB to go with it for a separate pwer supply. Everyone says it dramatically improves the imaging, stereo separation, and overall sound output.
    Tube PCB: http://www.diyaudio.com/forums/group-buys/156149-tube-i-zator-professional-pcb.html
    B+ SHunt PCB: http://www.diyaudio.com/forums/group-buys/156149-tube-i-zator-professional-pcb-20.html
    Greg
