Bi-amping... use pre-outs w/crossover?
Sparky
Sparky Posts: 32
edited January 2004 in Speakers
I have a 200wpc amp (used) coming next week to add to my system (see below). I want to bi-amp using my receiver for the Main L/R highs and amp for Main L/R lows. The system is fine as it is now for 5.1, but in 2 channel mode I need more power for the 150s.
Now I know there are those that disagree about whether I should bi-amp using my receiver, but I want to give it a try. If it doesn't work then I go a different route. No big deal.
My question is, given the above scenario, where and/or should I use a crossover? Should I use a crossover on the pre-outs? Should I use a crossover on the highs? Both?
I'll be glad when I can sit down and enjoy this system for what it is and stop constantly thinking about how I can tweak it. It's supposed to be a source of enjoyment and relaxation, not one that adds stress and takes up much of my free time. Does it ever stop? I'm enjoying the learning process but not at the expense of listening time.
Thanks for the help,
Sparky
Mains: Polk RTi150 (bi-amped 200 x 2)
Center: Polk CSi40
Surrounds: Polk TC80i
Rear: Polk RTi38
Subs: (2) SVS 20-39 CS+
PrePro: B&K Ref 50
Amp1: Sherbourn 7/2100A (200 wpc x 7)
Amp2: Sherbourn 7/1250A (125 wpc x 7)
SubAmp: Denon POA2800 (350 wpc x 2)
DVD: Denon DVM-2815
DVR: Dish Network PVR508
Sat: Dish Network 301
Panamax Max 5300
Panamax Max 2-20
Post edited by Sparky on
  • Fireman99
    Fireman99 Posts: 129
    edited January 2004
    You may want to look into the (Amps) current that your recever and the new amp puts out. The reason I mention this is I biamped my 150's to 200wpc at 45amps and actualy lost bass response from the speakers compared to the 110wpc at 85amps the recever kicks out. If your new amp has more current then the recever ou should notice a pick up in the bass response.
    Hope this helps a little.
    Dan
    P.S. If your a tweak freak like me it will never end just enjoy what you got and tweak it and enjoy even more =)
    Recever AVR 8000
    Amp PA 4000
    CDR 26
    Mains RTI 150 Bi wired
    Center CSI 40 Bi wired
    Surround FXI 30
    Rear RTI 4
    Sub PSW 140
  • Sparky
    Sparky Posts: 32
    edited January 2004
    Hi Fireman99,
    Ok, now I have a really stupid question for you. Where do I find the current/amps for my receiver? I can't find anything in the Operating Instructions?
    Thanks,
    Sparky
    Center: Polk CSi40
    Rear: Polk RTi38
    PrePro: B&K Ref 50
    DVD: Denon DVM-2815
    Panamax Max 5300
    Panamax Max 2-20
  • ntculenuff
    ntculenuff Posts: 1,146
    edited January 2004
    too answer this ?....
    NO
    tweaking is what makes it fun:confused:
    just when you can say this sounds incredible you will say "i just need......." too complete the set up
    Speakers:
    Definitive BP7001sc mains
    Definitive C/L/R 3000 center
    Polk RT800i's rears
    Definitive supercube I Sub
    Audio:
    Onkyo TX-NR3010
    Emotiva XPA five Gen 3
    OPPO BDP-103 CD, SACD, DVD-A
    Video:
    Panasonic TC-P65ZT60
    OPPO BDP-103 Bluray
    Directv x's 2
  • Fireman99
    edited January 2004
    Look in the owners manual under specs it should say in there or go to the web site for the recever and see if they have an downloadable spec sheet for your recever.
    Dan
    Recever AVR 8000
    Amp PA 4000
    CDR 26
    Surround FXI 30
    Rear RTI 4
    Sub PSW 140
  • walk
    walk Posts: 178
    edited January 2004
    You don't need a crossover, the speakers have one built-in.
    - Sony 50"A3000 SXRD; Onkyo TX-SR 805
    - Polk RTi150 mains; CSi30 center; FXi3 surrounds, R15 backs
    - Velodyne CHT-12 subwoofer
  • pjdami
    pjdami Posts: 1,894
    edited January 2004
    This is correct. Remove the brass jumper plates on your 150s and run the receiver speaker outputs with speaker wire to the top binding posts on your speakers. Then run the preamp out on your receiver to the amp and run speaker wire from the amp to the bottom binding posts on your speakers. If your amp has a variable input gain adjustment, you can then adjust your amp so that your bass matches your highs. If your amp has a fixed gain then you very well may have too much bass because of the mismatch in watts between the amp and the receiver and the sound will be unbalanced.
  • Tour2ma
    Tour2ma Posts: 10,177
    edited January 2004
    Correct about the cross-over. An external would not even be an option with the AVR supplying half the amplification.
    F99,
    Not sure about your 2 ch amp, but your AVR amperage rating is likely to be a total for all channels.
    More later,
    Tour...
    Vox Copuli
  • Sparky
    Sparky Posts: 32
    edited January 2004
    Thanks for all the input guys. You saved me from spending some hard earned money on another gadget.
    I can't find the amperage for my receiver anywhere. It's not in the spec sheet and Denon has nothing online for this "older" model. Is it important to know what the amperage of the AVR is before I hook up my amp?
    Thanks,
    Sparky
    Center: Polk CSi40
    Rear: Polk RTi38
    PrePro: B&K Ref 50
    DVD: Denon DVM-2815
    Panamax Max 5300
    Panamax Max 2-20
  • Fireman99
    edited January 2004
    It is just one less varriable if you know it. Will it affect performance... maybe but it won't hurt your equipment to hook it up and test it out with your own ears.
    Dan
    Recever AVR 8000
    Amp PA 4000
    CDR 26
    Surround FXI 30
    Rear RTI 4
    Sub PSW 140
  • Tour2ma
    edited January 2004
    Even when you can find amperage specs, they are stated differently by different manf's... Some do state per channel; others state the sum total for all channels.
    More later,
    Tour...
    Vox Copuli
  • Fireman99
    edited January 2004
    Tour you are correct with the system amps my recever is capable of +/- 85 amps of HCC and the Amp is capable of +/- 45 amps of HCC. My recever is a 5.1ch with pre outs for 7.1 and the Amp is a 8 ch amp.
    I was just helping Sparky to understand that now all Watts are equal there are other variables in the equasion.
    Dan
    Recever AVR 8000
    Amp PA 4000
    CDR 26
    Surround FXI 30
    Rear RTI 4
    Sub PSW 140
  • Sparky
    Sparky Posts: 32
    edited January 2004
    Guys... I feel like an idiot here. Trust me, I'm not. :-) I have both manuals (Denon AVR-5600 and Denon POA-2800) here in front of me and the word "amp" does not appear in the Spec sheet for either one. What am I missing? There are all the specs for Watts but I assume you are looking for Watts and NOT Amps. Can someone explain the difference to me?
    Thanks,
    Sparky
    Center: Polk CSi40
    Rear: Polk RTi38
    PrePro: B&K Ref 50
    DVD: Denon DVM-2815
    Panamax Max 5300
    Panamax Max 2-20
  • Sparky
    Sparky Posts: 32
    edited January 2004
    I may have found something. In the Power Consumption Section for the amplifier it says 9 A and for the receiver 9.1 A. Is this what you were referring to? These numbers sound low to me, but then again, I have no idea what I'm talking about.
    Sparky
    Center: Polk CSi40
    Rear: Polk RTi38
    PrePro: B&K Ref 50
    DVD: Denon DVM-2815
    Panamax Max 5300
    Panamax Max 2-20
  • Fireman99
    edited January 2004
    Sparky what your refering to there is the cosumption of the recever (how much power it draws from the AC outlet.
    I was just looking over a Dennon recever book and It doesnt show the Current or amps for there recever. You could E-Mail them and ask for the HCC (High Instantaneous Current Capability) of your two models and they should be able to give you an answer.
    Dan
    Recever AVR 8000
    Amp PA 4000
    CDR 26
    Surround FXI 30
    Rear RTI 4
    Sub PSW 140
  • Sparky
    Sparky Posts: 32
    edited January 2004
    Thanks Dan, I'll do that.
    Sparky
    Center: Polk CSi40
    Rear: Polk RTi38
    PrePro: B&K Ref 50
    DVD: Denon DVM-2815
    Panamax Max 5300
    Panamax Max 2-20
