I just ordered this for my VMPS -
VR3
VR3 Posts: 29,497
edited February 2011 in DIY, Mods & Tweaks
http://www.parts-express.com/pe/pshowdetl.cfm?&Partnumber=293-682
From what I have read I am going to add 2,000 gram of weight to it...
This should be a huge upgrade for my system...
That Passive Radiator Brian gives you is horrible. It can barely handle the back pressure from the two active drivers...
This one moves a solid 3" peak to peak so should be able to travel far more than the VMPS one could dream of...
And if it sounds worst I will just return it - no biggie
Post edited by VR3 on
    treitz3 Posts: 20,048
    edited November 2010
    I don't get it. The passive only moves...what? a 1/4"? 1/2" at most?
    Why in the hell would you want a 3" excursion?
  • Face
    Face Posts: 14,340
    Just curious, what formula did you use to determine the additional mass needed?
  • AudioGenics
    AudioGenics Posts: 2,567
    that is some interesting passive radiator design.
    very complicated IMO.
    personally pricey too for something that is passive
  • zingo
    zingo Posts: 11,258
    Good luck with the install and I hope it makes a difference; no matter what it looks awesome though...
    VR3 Posts: 29,497
    TC Sounds have a mass graph to show how to change the FS to as low as 10hz --
    I am just guessing with my drivers that 2,000 grams will do it.
    Shall see
    VR3 Posts: 29,497
    Well I got this installed last night -- the new one was a little larger than the old one in the frame.... so I had to chisel at the route for a bit to make room for it --
    Well worth it though as we ran through some popular selections (TF 1 & 2 of course) and we cranked the VMPS about 5 DB hotter than before - which before would have causes this thing to go absolutely bonkers) and the VMPS sounds throatier, deeper, fuller - and has far more tactile impact than it could ever fathom before....
    Did I mention I did not hear any bottoming out ever?
    Anyways - at first I threw half the weight on there and later went back to throw it all on there and that seems to be the best method...
    Anyways -- well worth the investment
  • Face
    Face Posts: 14,340
    The OEM radiator seemed undersized, good job!
    VR3 Posts: 29,497
    The OEM radiator is horrible, it is a single 15" that moves line 3/4 of an inch -- and has to balance an active 15 and a 12...
    That thing hits the basket like its trying to break out of jail...
    I moved it to a different corner since I am getting rid of my tyler acoustics subs and now it is about 17 ft away - can you say AWESOME???
    Oh man ---
    Once my Outlaw amp gets here for my centers I will be rockin and rollin
  • engtaz
    engtaz Posts: 7,669
    Congrats on the improvements. Every once and a while a plan works.
    engtaz
    VR3 Posts: 29,497
    Funnier occurance --
    Brian has a new upgrade for the Larger Subwoofer... guess what it is??? TC SOUNDS woofers that compliment my passive radiator!!! HAHAHHAHAHA!!!
    So first of the year I am going to get the 12 and 15 that matches
    VR3 Posts: 29,497
    index.php?action=gallery;sa=view;id=43715
    VR3 Posts: 29,497
    We played Assault on Home Tree tonight with Tom and Russ here --
    We had it at Reference Levels, plenty of subsonics and ZERO bottoming or hints of distortion.
    Unfreakin belieable
  • Conradicles
    Conradicles Posts: 6,362
    Trey, I just pulled the trigger on a VMPS 215 sub with megawoofer upgrades (old style) on the driver and passive.
    Are you still impressed with this TC passive radiator?
    VR3 Posts: 29,497
    yes the vmps is garbage imo without the pr upgrade for ht... For music it is great stock and better than the tc upgrade. Imo
