WTB: Amp that can handle 4 ohms
Pycroft
Pycroft Posts: 1,961
edited December 2010 in Wanted (WTB) Classifieds
I am about to (Hoping not to jinx it) purchase some sony SS-M9's which are 4 ohms and VERY power hungry. I'm thinking my ST-70 will not handle them. I need to search what is available in the 4 ohm - 300+ wpc (The more the merrier) power amp. If anyone has a suggestion, or has something that fits the bill, let me know. Thanks,
James
2 Channel/HT:
Sony SS-M9 P's (ES version)
Sony SS-M1CN Center Channel
Polk RT800 Surround Speakers
Odyssey Stratos Dual Mono Amplifiers
TAD 150 Signature Tube Preamp
Harman Kardon HK354
Sony SACD Player
Post edited by Pycroft on
  • Face
    Face Posts: 14,340
    edited November 2010
    Check out Wyred 4 Sound.
  • thuffman03
    thuffman03 Posts: 1,325
    What is your budget?
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • Pycroft
    Budget---good question. I was thinking perhaps around 600 bucks or so. Obviously the Wyred4Sound looks out - at least the new ones that are around 2,000. To be honest, I woul dhave to sell what I have now before I buy, so a lot has to do with how much I get can get for some of my stuff.
    James
    2 Channel/HT:
    Harman Kardon HK354
    Sony SACD Player
  • rdb2001
    rdb2001 Posts: 791
    B&K reference 200.2, 4420, 2220. Should be able to find one of those in your price range. I own the 2220 and it puts out 350-375 in 4 ohms (75 amp peak to peak). Very powerful amp. I run my martin logans with ease with them and they are 4 ohm speakers also.
  • Face
    Face Posts: 14,340
    Pycroft wrote: »
    James
    I would recommend the ST-500, which can be purchased used for around $1200, new $1500. But that's still above your budget.
  • thuffman03
    For $600 you have a lot of options if you are willing to buy used.
    billbillw Posts: 7,523
    James,
    I really hope you get those speakers. You will be moving into new territory with them and my advice would be to save up for awhile and see if you can double your budget.
    I honestly don't think many amps in the $600 range will really do them justice. Maybe a Parasound HCA-2200ii or a really low selling McCormack DNA-1. If you can get up to the $1000-1200 range, you can probably snag a Halo A21, a DNA-225, a Classe 25, or a Belles 350A, all of which would make the SS-M9 proud.
  • dcmartinpc
    dcmartinpc Posts: 844
    I would go with a Parasound HCA-2200II. 385x2 into 4 ohms and a very solid reliable amplifier. Just have to keep your eyes open.
    Don
    Living Room: Adcom GFP-750 (Upgraded), Squeezebox Touch, Oppo BDP-83, Pioneer DV-79AVi, Parasound HCA-3500 (Upgraded), SDA SRS 2 P/B (Gimpod, Sonicaps, & Mills)
    Theater: Denon 4311ci, Oppo BDP-93, Parasound HCA-2205+HCA-2200II, Polk LSi9, LSiC, LSiFX, LSi7, Custom 18" TC Sounds sub with 2 18" PR, Sharp XV-Z12000, Pioneer Kuro KRP-500M (isf Enabled)
    Bedroom: HK AVR354, Pioneer DV-47a, Parasound HCA-1500a, Polk LSi9
  • EDUBAG
    EDUBAG Posts: 403
    adcom 555, rotel 990bx, parasound 2200.
    HT:
    POLK AUDIO RTI4 FRONTS
    CSI3 CENTER
    DEF TECH PROMONITOR800 SURROUNDS
    PSW 125 SUB
    PIONEER ELITE AVR23TXH AVR
    APPLE TV 160GB
    PANASONIC BLURAY PLAYER
    50" PANASONIC PLASMA TCP50C2
    2 CHANNEL:
    KEF R300 THREE WAY BOOKSHELF GLOSS PIANO BLACK
    ROTEL RC 990BX PRE
    ROTEL RB 990BX AMP
    OPPO DV980 (AS CD PLAYER)
    PIONEER PL100 TURNTABLE WITH SHURE MX97E CART
    MIT EXP2 SPEAKER CABLES
    EDUBAG wrote: »
    Adcom is too grainy for the M9; the Rotel probably would melt down trying to drive the M9. As was already pointed out, the Parasound is a choice at that price.
  • starkiller
    starkiller Posts: 2,723
    Do you want used? How about cosmetics?
    Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
  • thsmith
    thsmith Posts: 6,082
    what efficiency are the speakers ?
  • George Grand
    George Grand Posts: 12,258
    I'd have public sex with a real dog if I could own a mint pair of those Sony. Shame you can't keep the little ones for use down the road somewhere. Or as surrounds.
  • George Grand
    Hey BillbillW,
    Do you think a 100wpc NAD 2200 has enough roast beef behind it to be up to the task?
    Hey BillbillW,
    Nope. BTW, the SS-M9 are ~89dB efficient, but the problem is they run 3 ohms from 10kHz on up. It brings out the harshness in lower quality amps.
  • AudioGenics
    AudioGenics Posts: 2,567
    + on the Rotel
  • George Grand
    billbillw wrote: »
    Oh well. Thanks.
  • orrb_05
    orrb_05 Posts: 215
    Outlaw M2200 mono block - it's rated at 300w for 4ohms.
    Amazon has 'em for $325 plus S/H direclty from Outlaw.
    Check audiogon as well. There is a set of four and I believe the seller is letting them go individually for $250 ea, or best offer - warranty is transferable.
    I've had two for under a week and am very impressed so far - great sound - great build quality.
    orrb_05 wrote: »
    Class D? Not up to the quality of the SS-M9. You guys need to remember these were $3500 speakers in the late 90's and they were considered a steal at full price by the reviewers. (Stereophile Class B, barely missed being Class A)
    These are the type of speakers that deserve near reference quality components in every step of the chain.
  • Face
    Face Posts: 14,340
    billbillw wrote: »
    :rolleyes:
    There's nothing wrong with the newer class D amps. Some prefer them to A and A/B. FYI, Outlaw monoblocks are a hybrid Class G/AB.
    Face wrote: »
    :rolleyes:
    Regardless, I don't think anyone would put Outlaw amps in the category of reference quality for a 2-ch system. They are home theater oriented.
  • Face
    Face Posts: 14,340
    That I agree with.
    nooshinjohn Posts: 25,905
    Sunfire Stereo 300~2 doubles down to 600wpc at 4 ohm. This might be a good option, but it will be a tad more than 600 bucks.
  • classic carl
    classic carl Posts: 661
    I have a minty Crown DC-300A from around 1982 that is rated at 155 wpc @ 8 ohms and 240 wpc @ 4 ohms. Someone on AK told me that his DC-300A tested out at 200 wpc @ 8 ohms. My amp was recently serviced to check DC offset and install RCA output jacks to replace the 1/4" jacks. This amp is a beast at 45 lbs. I will be driving from NW Pa. to Philly after Xmas. The photos were taken before the RCA jacks were installed.
    Main System 2.2:
    Proton AA-1150 ~ Yamaha C-4 ~ Furman Elite-15 DMi ~ Sennheiser HD600 ~ Monitor Audio Silver RS8
    (2x) Martin Logan Dynamo ~ Marantz CD5003 ~ Squeezebox Classic ~ Music Hall dac25.2 ~ Sansui D-X111R
    Dual 1229/Acutex M312 III STR ~ Music Hall mmf-5.1/Goldring 1012GX ~ Music Hall Cruise Control 2.0
    Home Theater 5.2:
    Yamaha RX-V800 ~ Furman Elite-15 DMi ~ Polk Audio RT55i ~ RT35i ~ CS400i ~ (2x) PSW450
    Winter Residence 2.1 (laptop system):
    Yamaha RX-485 ~ Squeezebox Classic ~ Topping D30 ~ EPI M90 ~ Dayton Audio SUB-1200
  • thuffman03
    +1 on the Sunfire!
  • Pycroft
    George -
    I may give you my speakers to see you publicly humiliate yourself :)
    Cosmetics is 'Little' concern, but always a bit :) Used is perfect. I have no time now, but am doing some research on what you have all said. Thanks, and keep it coming.
    James
    2 Channel/HT:
    Harman Kardon HK354
    Sony SACD Player
  • starkiller
    Reason I asked about cosmetics is that I have a Crest 4000 amplifier that has seen better days but was recently gone through by a shop in Seattle and after replacing a few parts it was good to go. It's stable down to 4 and 2 ohms.
  • orrb_05
    orrb_05 Posts: 215
    billbillw wrote: »
    Well, based on the OP's $600 budget I don't think he's going to get anything along the lines of Goldmund :tongue:
    Hence my Outlaw suggestion.
    orrb_05 wrote: »
    I've been talking to James privately and I think he realizes he might need to increase his budget to get him where he wants to be. He might have a line on a McCormack that would give the Sonys some pretty good power.
    tonyb Posts: 33,072
    billbillw wrote: »
    If you could find a McCormack for anywhere near his budget, thats a steal. The DNA 500 would be my choice, but I have never seen one under 2 g's.
    If your Sony's are power hungry John, you need current,not necessarily watts. Look into some used Musical Fidelity amps too, or even a used B&K would drive those puppy's just fine.
