Xbox 360?
greg2350
I was thinking of buying a xbox 360 4gb model can you hook up an external HD and it work the same as having an internal HD I have a spare external usb drive. Thanks for any replies.
TV: Philips 42" LCD 1080p
Front Speakers: Polk Audio RT800i
Center Speaker: Polk Audio CS1
Surround Speakers: Polk Audio R50's powered of Denon AVR
Subwoofer: Polk Audio DSW pro500
AVR: Denon 3801
DVD Player: Denon DVM 745 upscale 1080p
Sat: Directtv HD 10
Front Speakers Amp: Rotel RB 890
Center Speaker amp: Rotel 970 BX
AVR: Denon 3801
Sat: Directtv HD 10
Post edited by greg2350 on
You can use an external hard drive for your own media, but not for game-related stuff like save games or install-to-disc. Plus, some games like Halo: Reach don't let you use all the features unless you have the hard drive, and stuff like Netflix, Zune, etc. requires it as well. Get the 250gb 360 instead.Equipment list:
Onkyo TX-NR3010 9.2 AVR
Emotiva XPA-3 amp
Oppo BDP-93 Blu-ray player
Epson 8500UB 1080p projector
Elite Screens Sable 120" CineWhite screen -
Thanks I will get the 250gb.
AVR: Denon 3801
Sat: Directtv HD 10
Center Speaker amp: Rotel 970 BX -
Prior to April 2010, you could only use an external harddrive for media. Since the update, you can connect an external hd or flast drive to your xbox and use it like an internal harddrive. I have borderlands and some demos on my external hd and it runs perfectly fine. If you buy the 4gb, just remember that even if you hook a 500 gb hdd up to it that you'll only be able to use 16 gbs of it. When I hooked mine up and formatted it, it said that it failed the test, but it works fine. Most external harddrives will fail, but work without any issues.
Here's a link with more information: http://www.xbox.com/en-US/storage/
If it were me, I'd just spring for the 250 gb console, but if you already have an external hdd, this is the cheaper route. -
Oh, yeah... I forgot they opened up hard drives to 16gb when they added the flash drive compatibility. But still, the 250gb is the better option overall, because SATA is faster than USB. Good catch though, man.Equipment list:
Emotiva XPA-3 amp
Is the new xbox 360 SATA instead of USB? The old ones were SATA drives, but USB interface since it technically just snapped on the top - that's why you could use the transfer kit they had.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
You can use flash drives to install games on them. You often will get slighter better loading times. I might buy a fast 16GB flash drive to try it :biggrin:, even though I play a lot less than what I used to do :frown:
TVs: Samsung S95B 65" QD-OLED (den) and LG C2 42" OLED (office)
Receiver: Denon AVR-X3700H (den) and Denon AVR-X2300W (den)
SACD and DVD-A player: Oppo BDP-83
Mains: Polk RTi8 (den) and Dali Ikon 8 (office)
Center: Polk CSi5 (den) and Polk CSi3 (office)
Surrounds: Polk FXi5 (den) and Velodyne surrounds (office)
Sub: SVS PB-2000 (den) and PCi 16-46 (office) -
The old drives snapped onto the top, but the header it plugged into was modified SATA. The new drives are straight SATA, so no special plug. The transfer kit is basically a USB to SATA adapter, which isn't as fast as straight SATA.Equipment list:
Emotiva XPA-3 amp
Look on ebay and you can find the OEM type drives for $50 or so.Shoot the jumper.....................BALLIN.............!!!!!
