Fair price?
What would you guys consider a fair price for a 2 pairs of RTi A1s and a CSi A4? They are in excellent shape except a nick from the factory on the center behind the grille. I have them up on audiogon and so far no nibbles...just want to make sure I'm not way out of line...Thanks in advance.
Post edited by mtbeck on
Free!
Just kidding. Are there others on audiogon that you can compare? Did you try to search eBay and see what they are going for there? That is about all I can give you since I don't follow the going market price on those speakers.
Good luck with your sale!Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t -
Thanks, I did. Audiogon currently has no other RT/CSi series speakers unfortunately. The Bay doesn't really have too many other than the refurbs from polk, which are going for 240 a pair and 225 a center. The problem is there are no other used ones. I guess I'll just let people make offers if they are really interested. Thanks for the reply though.
I would say something right below the polk direct ebay price is probably fair. Take 10-15% off of what they charge for refurbished stuff, that would probably be a decent starting point.Living Room 7.1 HT Rig:
M70 | CS2 | M60 | Atrium5 - Surr. | SUB - Emotiva ULTRA12 + Tara Labs sub cable | Pioneer Elite VSX-52 | Parasound HCAs 1000A | Sony BDP-S790 | Belkin PureAV PF60 | MIT Exp2 Wires
Bedroom 5.0 HT Rig (Music/Movies/Gaming) :
LSi9 | LsiC | Lsi/fx | Marantz SR7002 | NAD T955 | Sony BDP-S360 | Belkin PureAV PF30 | AQ Blue Racer II ICs & AQ Type 4 wires | PS3 -
Ok thanks, thats what I was thinking. I have it priced at 600 and I think that should be fair. I just figured some people around here might know better than me. Thanks for the help guys.
