CS2 Seris II On Sale at Newegg - $110 Advice?
SpartanStang14
SpartanStang14 Posts: 22
edited November 2010 in Speakers
I just wanted to share that the CS2 Series II is on sale at Newegg for $107.99 with $2.99 shipping if you use the code EMCZZZN29.
Also, I wanted some advice on whether or not you guys think it's worth the upgrade for me. Right now, I have a CS1 for my center, Monitor 60 Series II's up front, T15 bookshelf speakers in the back, and a PSW505 sub. I am worried about the size as well. I know it's supposed to be huge, and I will have to build a shelf to put it above the TV (rear projection big screen, so I can't put it under the TV). What do you guys think?
_______________________________________
AVR Sony STR-DH810
FRONTS Monitor 70 IIs
CENTER CS2 II
REARS Monitor 60 IIs
SUB PSW505
    EndersShadow Posts: 17,753
    Dont think its worth the upgrade. I have used both and while the CS2 is better its not worth replacing a CS1 with...
    Also if you do replace it, buy one of these guys...I use it on my RPTV and it works wonders....
    http://www.amazon.com/gp/product/B00067AIEU/ref=oss_product
  • K-daugh
    K-daugh Posts: 467
    i just upgraded my cs1 to a cs2 and i absolutley love it i think its much better than the cs1 ....better imageing and clarity ...bigger is better ...lol if you have the room for it i would definately make that upgrade
    Budget 5.1 H.T. Set Up
    HK avr 247 - Adcom GFA-7605:mrgreen::mrgreen: - Belkin PF60 Power Conditioner - Cs2 center channel - Monitor 60's fronts - Monitor 30's rears
    Mirage Bps 150i powered sub - 40"Samsung LCD ln40c530 - Sony Blu Ray Player BDP-S370 - Comcast digital hd box(motorola dcx3400)
    Monoprice Premium Interconnects Monoprice Ultra Slim HDMI w/Redmere:mrgreen: -Knukonceptz Kord 10 Gauge Speaker Wire - Nakamichi Banana Plugs
    Custom Jumpers
  • eastvanmikee
    eastvanmikee Posts: 1
    I just tried to order, and it says promo code EMCZZZN29 not valid. Am I doing something wrong or was this a one day thing only?
  • SpartanStang14
    I think that you have to be an e-mail newsletter subscriber to get the deal. If you log in and go to My Account at the top right by the shopping cart then on the left side under options click Subscriptions. Then check the box next to subscribe for the Newegg Newsletter. I hope that works for you! :)
    AVR Sony STR-DH810
    CENTER CS2 II
    SUB PSW505
