Matched Sound for LS50's
bokelleher
bokelleher Posts: 3
edited January 2004 in Speakers
Hello all,
I need some advice on which center channel and rear effect speakers that can best be "voice matched" to my existing LS50's.
Should I just shop ebay for a CS350LS or will the current models match the voice of my LS50's?
Thanks in advance!
Bo
  • wallstreet
    wallstreet Posts: 1,405
    edited January 2004
    The 350ls will be a perfect match. The 400i shares the same tweeter, but slightly different mid range. Although the difference is not noticeable. I run the 400i with my 90's and I've got a seamless front soundstage. I've also got the 350, but the 400i outperforms the 350.
