What gauge?
Systems
Systems Posts: 14,872
edited January 2004 in Car Audio & Electronics
I'm going to be wiring some speakers soon. They will have 50 watts RMS going to each speaker. What gauge speaker wire should I use?
Testing
Testing
Testing
  • LittleCar_w/12s
    LittleCar_w/12s Posts: 568
    edited January 2004
    hmm 50w? well you could use a piece of string for that.... :D
    Use a 14 ga for good upgradeability. You only really need 16 but since you're there...
    ___________________________
    Total cost of materials: Going up...
    Time spent: Countless Hours...
    Cranking the system, having it quiet outside the car, and sound that takes the rear-view off inside: PRICELESS
    For some things in life, you pay others to do it... For a masterpeice, do it yourself.
  • sntnsupermen131
    sntnsupermen131 Posts: 1,831
    edited January 2004
    Im going to hook up my 4x6s with 16gauge, theyll have roughly 50 watts going to each
    if youll want to upgrade later...then 14, if not, 16 is more than enough
    -Cody
  • Systems
    edited January 2004
    18 is fine unless you're bumping up to 100 anytime soon.
    Testing
    Testing
    Testing
