What gauge?
Systems
I'm going to be wiring some speakers soon. They will have 50 watts RMS going to each speaker. What gauge speaker wire should I use?
Testing
Testing
Testing
Testing
Testing
hmm 50w? well you could use a piece of string for that....
Use a 14 ga for good upgradeability. You only really need 16 but since you're there...___________________________
Total cost of materials: Going up...
Time spent: Countless Hours...
Cranking the system, having it quiet outside the car, and sound that takes the rear-view off inside: PRICELESS
For some things in life, you pay others to do it... For a masterpeice, do it yourself. -
Im going to hook up my 4x6s with 16gauge, theyll have roughly 50 watts going to each
if youll want to upgrade later...then 14, if not, 16 is more than enough
-Cody -
18 is fine unless you're bumping up to 100 anytime soon.Testing
Testing
Testing
