any help will be appreciated
Dreadlord
Dreadlord Posts: 1
edited January 2004 in Car Subwoofer Talk
I've just recently gotten into working on my stereo system(paintball came first$$$) I've had subs before but always had them installed profesionally. I found a great deal on 2 GNX124 subs and I know I'll be hooked on getting better and better sound out of my car. Time to DIM(do it myself) I have a 2001 olds alero coupe and was wondering what info I could get from you old schoolers on Sub box fabrication, Head units, amps etc... without spending a fortune right off the bat. I would eventually like to get into amature comps. sorry I'm rambling I would be more than happy to help any of you out with Paintball tips or anything else I know.
Obey the Dreadlord
Post edited by Dreadlord on
  • Systems
    Systems Posts: 14,872
    edited January 2004
    amateur competition will cost you much more than you're willing to spend... worry about making your car sound pleasant to you and you alone right now... i've spent a fricking assload and i really do doubt that i'd take my truck to the lanes and do well ever... not enough $$... not enough time... not enough people... and thus not enough know how.
    build your box out of whatever -- the gnx can do well in a particle board box... and that stuff is cheap as hell. screw and glue it together, caulk the seams... larger more power hungry subs would do better in 3/4" mdf boxes or better yet 3/4" cabinet grade birch plywood boxes --- but by the time u by the birch ply you could have gotten two more gnx subs... so don't bother just yet.
    Testing
    Testing
    Testing
