Carver vs emotiva
13»
  • Dawgfish
    Dawgfish Posts: 2,554
    edited November 2010
    Pinktulip7 wrote: »
    Problem solved..:biggrin: I rewired or reconnect all my interconnect cable along with Speaker Cables,Polk RTI A9 is Bi Amped by Carver M-1.5T(X2) without Sub(Stereo)now getting excellent Bass,Sounds are more warm and details.............
    That's good to here. I got the best results with my RTI-12s when I passively bi-amped them also. The bass was unreal configured in this fashion.
  • Pinktulip7
    Pinktulip7 Posts: 249
    Two(2)of my cables that connect Amp to Speakers found loose!!!Bi-Amping actualy make the Speakers 15% better specialy in the Low and Mid end...
    TV :>Panasonic TC-P55VT50
    RECEIVER :> HARMAN KARDON AVR 7300
    FRONT :> L & R :> POLK RTI A9 500 W
    AMP :1> PARASOUND HALO A21 250 W
    AMP :2> EMOTIVA UPA-1 200 W
    CENTER :> POLK LSiM 706c 250 W
    SURROUND SIDE :> POLK RTi A3 150 W
    SURROUND REAR :>POLK FXI A6 150 W
    DVD PLAYER(HD) :>TOSHIBA HD X-A2
    DVD PLAYER(BLU-RAY) :>Panasonic DMP-UB900
    POWER CONDITIONER :> PANAMAX M5400-EX
    SUBWOOFER :A> SVS SB16-Ultra 1500 W Front
    SUBWOOFER :B> SVS SB16-Ultra 1500 W Rear
  • anhchungdoan
    anhchungdoan Posts: 760
    Lateral move from one mid-end component to another mid-end component only results in some noticeable difference in sound but not necessarily results a better sound in term of image, decay, localization of instruments and vocals. That's why they are called mid-end gear.
    "Insanity is to do the same thing over and over again and expect a different result". Been there, done that and wasted a bunch of money and precious time, why don't you kick up a knot and get some audition for some real hi-end gear. YMMV.
    txcoastal1 Posts: 13,513
    cstmar01 wrote: »
    or you could always try and butter John up to sell you his mono blocks he's building :tongue:
    Ya John market that bad boys...I want a pair
  • cnoat
    cnoat Posts: 315
    TroyD wrote: »
    If he's using a receiver as a pre/pro....I'd also think about a separate pre/pro.
    BDT
    +1 A dedicted pre will show major improvement
    Parasound Avc-1800
    Mains-Rti 12 -Parasound 1500a
    Center-Csi5-Parasound 1000a
    Rears-Rti 8-Parasound 750a
    Sub SVS Ultra Tv 12
    Diamondback and King Cobra IC's
    AQ T4 SC
  • Pinktulip7
    xcapri79 wrote: »
    Sounds like you solved your problem and you are keeping your amps.
    in future I will be getting Parasound Amp...:biggrin:
  • Pinktulip7
    Also upgrading to HK 7550HD from HK 7300
  • Pinktulip7
    Real High end Amp?like what?
