Help needed! Between a couple AVR's
Pepsiaddict
Pepsiaddict Posts: 14
edited November 2010 in Electronics
Hey there, first of all, I have a pair of RTiA7's for fronts, and plan on getting the CSia6 center, and the FXi4's for surrounds. Now on to my dilemma.
I had originally decided on a Denon AVR991, but more thinking and research and I found that it doesn't have pre-outs, so that kind of killed it for me as I want to be able to hook up a dedicated amp for the RTi7's, (and also just for piece of mind for upgrading)
Now, I have it down to 2 others, one being the Yamaha 7.1 Multi-Room Receiver (HTR6295B)
quick link for those that dont know about it
http://www.futureshop.ca/en-CA/product/yamaha-yamaha-7-1-multi-room-receiver-htr6295b-htr6295-b/10135594.aspx?path=26c3cfc83b6599c8ffbf16c7cc5635aden02
or the Onkyo TX-NR808 7.2-Channel Network Home Theater Receiver
and link
http://www.amazon.com/Onkyo-TX-NR808-7-2-Channel-Network-Receiver/dp/B003N197EI/ref=cm_cr_pr_product_top
I like them both, if I could get some peoples opinions on both, and also maybe from people with Polk's and these manufacturers for AVR's in terms of sound quality with the Polks....warm, bright, no good, whatever lol..
Thanks for the time :)
Post edited by Pepsiaddict on
  • eclimax13
    eclimax13 Posts: 168
    no denon?
    Theater: Epson 8500ub, Elite 120" screen, Lsic, Lsi25, Lsifx, SVS Pc12plus, SVS Pc12plus, Emotiva Xpa-5, Denon Avr3311ci, Sony Bdps1000es
    Living Room: Panasonic TCP58VT25, PS3, Energy FPS, Onkyo Tx sr707, Sony Ps3, DswmicroPro 2000
    Bed Room: Panasonic TCP50x1, Samsung Bd c7500
    Weight Room: Panasonic TCP46G10, Polk Pswi225, PS3
  • Pepsiaddict
    Would have loved one, but the higher end ones are not sold where I am shopping, and are also out of my pricerange =/
  • eclimax13
    avr3311ci can be had for $800 online...are you only shopping local?
  • Pepsiaddict
    Locally only yes, and I'm REALLY trying to get one at Futureshop...since I can use their card to get one this weekend
  • dorokusai
    dorokusai Posts: 25,576
    Onkyo.
  • eclimax13
    then the onkyo...excellent sound when i was running mine with my theater setup (replaced by the denon)...yamahas have always sounded a bit bright to me...only thing i dont like about the onk is lack of audyssey multeqxt which was a noticeable difference from multeq
  • TORI3
    TORI3 Posts: 234
    Never heard either of the models, but used to own an Onkyo. Just from reading this forum, it appears that the majority of the members own an Onkyo. With that being said, I've never really heard anything negative about the Yamaha's.
    I don't think you could go wrong with either one.
    Not much help, I know. Maybe someone with your speakers and those particular models can chime in...
    HT: RTi8s, CSi3, RTi4s, HSU ULS-15, Pioneer Elite VSX-23TXH, Sunfire Cinema Seven.
    2CH: CJ MF2300, Parasound P3, PS Audio DLIII, Wadia 170i, Music Hall Maverick, Sierra-1s, Sunfire HRS8
  • dorokusai
    Well, stick around for more opinions but get ready for suggestions you never asked for...good luck.
  • eclimax13
    http://www.amazon.com/Denon-AVR3310CI-7-1-Channel-Network-Receiver/dp/B002AKKFQ2/ref=sr_1_1?ie=UTF8&qid=1289449401&sr=8-1
    i know you said locally but this is a deal no one looking for a receiver should overlook...i know if i was in the market id be all over this
  • Jetmaker737
    Jetmaker737 Posts: 1,113
    I've never owned a Yamaha but have been very happy with my Onk. So I vote Onk.
  • Pepsiaddict
    eclimax13 wrote: »
    I just checked, and there is no shipping for that to Canada, bummer. This is why I normally don't bother looking at online stores :p lol
  • leroyjr1
    leroyjr1 Posts: 8,785
  • PrazVT
    PrazVT Posts: 1,607
    Yeah I have the Denon 3311ci and have been very happy with it. Features galore, pre-outs, and warmish sound.
    I believe the higher end Yamahas aren't as bright as my Yamaha 663, so that might be worth a look. Yamahas are pretty solid. You get pre-outs on the new RX-A800 and higher.
    My dad has an Onkyo TX-SR707 and sound quality is very nice and it has pre-outs. He needs an amp, though. Driving 7 speakers, it struggles (-17dB to watch TV at reasonable vol), but that's why we use amps.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
    tonyb Posts: 33,069
    In your price range, the Yamaha is going to be bright, with Rti speaks that are also bright,maynot be a good match. Denon or HK are warmer, maybe a better match untill you get an amp. Also put some thought into cables.
  • mdaudioguy
    mdaudioguy Posts: 5,165
    tonyb wrote: »
    Yep, +1. Been there, done that (Yamaha/RTi). Onkyo was a bit better, but HK was the best solution of the three I tried. I stopped thinking about trying others after getting the HK. Good luck! :smile:
  • B Run
    B Run Posts: 1,888
    I used the Yamaha/Rti setup for a while and agree it was too bright, I ended up going with the Pioneer 1120 and I feel like it sounds much better. I was very close to getting the 808 but the Pioneer went on sale for almost $200 cheaper and it had a few more features.
  • dorourke07
    dorourke07 Posts: 298
    +1 on the Onkyo. Seems to be a step up from the Yamaha.
    Mains - LSi9's
    Center - LSiC
    Surround - pair of TL3's
    Amplification - Parasound 2125
    AVR - Onkyo 706
    CD/SACD - Onkyo DV-SP506
    SUB - MartinLogan Abyss
    55" Panasonic Viera TC-P55GT30 3D
    Bluray - DMP-BDT310 Panasonic
  • larry777
    larry777 Posts: 480
    I also have the Rti speakers ( Rti10,CsiA6 & Rti4's ) and have been doing research into a new AVR as the next step before adding an amp. I have also gotten great information from these forums. This is what I have found out so far. In General....Yamaha-Bright,Onkyo less Bright,Pioneer Neutral to Bright,Denon Warm to Neutral and Harmon Kardon Warm. Anyone please feel free to add comments to this rankings if not accurate. I have a Denon 888 now which does actually seem at least Warm to Neutral but dosn't have Preouts to add an Amp. The next step I started to research was this same Warm/Bright quality of Individual Amps....which I will start a new Thread about in a few minutes. The chosen Amp can also add to the desired warmness of my overall finished sound...I hope,but to be discussed in the new Thread.. I am also from Canada so have less options from On Line Shopping also.
    Home Theatre.............
    Pioneer SC-35
    Polk RTi10's Fronts
    Polk CSiA6 Center
    RTi4 Surrounds
    SVS PB-12 Sub
    2 Channel.............................
    Yaqin MC-100B
    Energy RC-70 Speakers
    Arcam CD-192 Disc Player
    Van Den Hul Interconnects
