whats the little dirty trick?!?
haroo
ive heard that some hifi stores do a nice little trick to some of there speakers, my understanding is they place a cap/resistior between the amp and speakers x-over.
what is the tweak?
how well does it work\what does is do exactly?
can someone help me to do this to my pioneere 8" fullrangers/paradyme tweets(in a diy carfea little big horn)?
and of course maybe my rt800i's...
thx to all
what is the tweak?
thx to all
--MARANTZ SR18ex 140wpc x 5 (high current/direct amp)thx-ex "ultra"
electrohome tube amp 15watt. pr channel(aprox.1955a.d.) for 2 channel audio{recently recapped& tubed-5ar4power rect. & 12au7)
-kenwood amp(km-996/140wpc(used for 7.1 rears(thx ex)
-toshiba dvd video/audio player(progressive scan) sd-4700
-sony sacd cd player scd-xe670
-nakamichi "music bank cd player "6+1disk(20bit dac)
-toshiba hifi vcr (v3 pro head)
-motorola digital cable box
-RCA 32' "home theater" PIP tv
-polk RT800i x 2 (mains) ~bi-wired
-polk sc400i x 1 (center) ~bi-wired
-polk fx300i x 2 (side fx) ~di-pole
-polk r10 x 2 (rears)
-polk pws250 (powered sub)
-2x173ltr(48"-16")sono subs(powered by kenwood kr-7200 250watt & w/ audiosource EQ (model eq eight/series II)
-Thorens td-166 mk II/Grado silver fs1
-Thorens td-160/empire 66cart
-Dual 601
-D.I.Y. carfea "little big horns"-(pioneer full range 8" & fostex 4" compression horn tweaters
-sony (ps1)
-sony (ps2)
-haroo, "GOD gave you the gift of sound, Your gift to God is what you do with it!"
"marantz haroo"
-Dual 601
-sony (ps1)
-sony (ps2)
"marantz haroo"
Post edited by haroo on
Many stores use potentiometers (or "pots") in line to speakers. These variable resistors allow easy volume matching of speakers of different sensitivities for A-B auditioning.
Only such use I am aware of, but is not a tweak and would serve no purpose in a home system.More later,
Tour...
Vox Copuli
What you are describing sounds like it may be a Zobel. They are often used to smoth out impedences in speakers, but many speakers have one in the crossover already.
Do a google on "zobel, zobel network, or zobel filter" and see what you can come up with. The single driver forum may also have good info.Make it Funky!
"F*CK , I HONESTLY READY TO SELL ALL MY PLOKS JUST ON PRINCAPAL"
You honestly ready accept tip from site that bad?:DTwo Channel Main
Receiver - VSX-54TX
Mains - Csi40's
Sub - Spiked Velodyne Cht-8 On Spiked Landscaping Stones
"If you could put speakers in a needle, I'd never see him again..." - My Girlfriend
