Rotel rmb1075 -->rmb1095?
eclimax13
eclimax13 Posts: 168
edited November 2010 in Electronics
i have lsi25, lsic, lsifx setup running off an rmb1075 which gives me 200wpc...i often play at reference level and dont feel my system is lacking power but would an upgrade to the rmb1095 be of any value or would i just be wasting my money? has anyone done this?
Theater: Epson 8500ub, Elite 120" screen, Lsic, Lsi25, Lsifx, SVS Pc12plus, SVS Pc12plus, Emotiva Xpa-5, Denon Avr3311ci, Sony Bdps1000es
Living Room: Panasonic TCP58VT25, PS3, Energy FPS, Onkyo Tx sr707, Sony Ps3, DswmicroPro 2000
Bed Room: Panasonic TCP50x1, Samsung Bd c7500
Weight Room: Panasonic TCP46G10, Polk Pswi225, PS3
Post edited by eclimax13 on
  • mantis
    mantis Posts: 17,554
    The RMB1095 sounds a lot better then the 1075. The "black" sounding back ground is the difference. I think it has to do a lot with the bigger power supply and caps. I owned the 1095 and I picked it over the 1075 due to the sound quality not the fact it has more power. It's 330 @ 4ohms.
    Sell the 1075 and get the 1095 , this is not a waste of money.
    Dan
  • resperc
    resperc Posts: 41
    check out the Rotel forum on HTguide.com
    there are numerous threads on this very subject (almost all came to the same conclusion as the post above).
    Most are a good read
  • eclimax13
    hmmm...went there but didnt find anything
  • resperc
    resperc Posts: 41
    just went there...try this...
    once on the Club Rotel page use the "search this forum" link. type in 1075 1095 and you should get tons of results. some are not specific discussions of these two amps, but by page 2 of the results there were some.
    either way...if you are contemplating Rotel that forum has tons of great information
  • eclimax13
    the only problem im seeing is that most of those guys are upgrading from 125 wpc to 200wpc because they have 8ohm speakers....im already getting 200wpc with my 4 ohm speakers so this is why im not sure how much more i need
  • angelsfann02
    angelsfann02 Posts: 589
    Can I get first shot at your 1075 if you sell? Thanks
    LIVING ROOM:
    Pioneer PDP-6070HD, Pioneer Elite SC-25, Pioneer Elite BDP-05FD,
    Emotiva XPA-5, Emotiva USP-1, Polk LSI15's, Polk LSiC, Velodyne 12", Mirage Nanosat Prestige rears, MIT AVT Speaker Cables, Audioquest King Cobra Interconnects, Panamax M5300pm Surge Protection/ Power Conditioning
    BEDROOM: VIZIO 32" LCD, Pioneer Elite VSX-23txh, Pioneer Elite BDP-23FD, Parasound HCA-2205A, Mirage Nanosat Prestige Speakers 5.1, Mirage S8 Sub, Monoprice cables, APC Surge Protection.
  • resperc
    resperc Posts: 41
    eclimax13 wrote: »
    This is a reasonable argument. I run my 4-ohm speakers on a 1075 and it sounds really good. I almost upgraded to a 1095, not for the volume, but the extra power gives it faster transients, clearer midrange, and better pitch and stability in the bass.
    I didn't do it, because I am giving up 5.1 and going back to stereo.
