Spikes on Carpet, Should I use it ?
I have LSi15 and they are not much stable on carpet so I used Spikes. Now they are stable but they are almost cutting through the carpet to the floor.
I am sacred that I am going to damage the carpet.
Advise ?
1. Whether I should use them or not ?
2. If yes, how do I take care of carpet issue.
3. Should place a hard woodden board underthe speaker so the spikes are on the that board but that will make them unstable again, if my guess is right.
Thanks in advance !
Advise ?
Thanks in advance !
Tapesh
Tapesh
Post edited by tapeshc on
They are supposed to go through the carpet into the subfloor. They shouldn't cause any damage as they are just poking a hole through the carpet and pad. The only thing I'd be careful about is when you move them, lift, don't slide. If you try to "scootch" them around it could snag the carpet. I think a board under would defeat the purpose. If you are really concerned, you might try some kind of cement or marble (or whatever) slabs underneath like some guys use to isolate their subs and use the rubber feet on top of the spikes. Just my .02
I'm using carpet spikes on my system, and they are helluva lot more stable now. I don't think they are damaging my carpet. If anything, they might be puncturing holes in the carpet pad....but thats the extent. Good luck!Home Speakers polkaudio RTi70's (bi-wired), CSi30, FX3000i, PSW250
Car speakers polkaudio EX 369, DB 650 -
I think Ken nailed it. Spike 'em to the sub floor.More later,
Tour...
Vox Copuli
Thanks for your responses !
I just wanted to make sure that its normal that spikes are going through the carpet.
I hope it wont do permanent damage.Thanks
Tapesh -
I am also sacred.
Two Channel Setup:
Speakers: Wharfedale Opus 2-3
Integrated Amp: Krell S-300i
DAC: Arcam irDac
Source: iMac
Remote Control: iPad Mini
3.2 Home Theater Setup:
Fronts: Klipsch RP-160M
Center: Klipsch RP-160M
Subwoofer: SVS PB12NSD (X 2)
AVR: Yamaha Aventage RX-A2030
Blu Ray: Sony BDP-S790
TV Source: DirecTV Genie -
had too spike my subs to my hardwood floors, damn things kept walking around on me:pSpeakers:
Definitive BP7001sc mains
Definitive C/L/R 3000 center
Polk RT800i's rears
Definitive supercube I Sub
Audio:
Onkyo TX-NR3010
Emotiva XPA five Gen 3
OPPO BDP-103 CD, SACD, DVD-A
Video:
Panasonic TC-P65ZT60
OPPO BDP-103 Bluray
Directv x's 2
