Spikes on Carpet, Should I use it ?
tapeshc
tapeshc Posts: 135
edited January 2004 in Speakers
I have LSi15 and they are not much stable on carpet so I used Spikes. Now they are stable but they are almost cutting through the carpet to the floor.
I am sacred that I am going to damage the carpet.
Advise ?
1. Whether I should use them or not ?
2. If yes, how do I take care of carpet issue.
3. Should place a hard woodden board underthe speaker so the spikes are on the that board but that will make them unstable again, if my guess is right.
Thanks in advance !
Tapesh
Post edited by tapeshc on
  • ken brydson
    ken brydson Posts: 8,980
    edited January 2004
    They are supposed to go through the carpet into the subfloor. They shouldn't cause any damage as they are just poking a hole through the carpet and pad. The only thing I'd be careful about is when you move them, lift, don't slide. If you try to "scootch" them around it could snag the carpet. I think a board under would defeat the purpose. If you are really concerned, you might try some kind of cement or marble (or whatever) slabs underneath like some guys use to isolate their subs and use the rubber feet on top of the spikes. Just my .02
  • ChrisDurano
    ChrisDurano Posts: 372
    edited January 2004
    I'm using carpet spikes on my system, and they are helluva lot more stable now. I don't think they are damaging my carpet. If anything, they might be puncturing holes in the carpet pad....but thats the extent. Good luck!
    Home Speakers polkaudio RTi70's (bi-wired), CSi30, FX3000i, PSW250
    Car speakers polkaudio EX 369, DB 650
  • Tour2ma
    Tour2ma Posts: 10,177
    edited January 2004
    I think Ken nailed it. Spike 'em to the sub floor.
    More later,
    Tour...
    Vox Copuli
  • tapeshc
    tapeshc Posts: 135
    edited January 2004
    Thanks for your responses !
    I just wanted to make sure that its normal that spikes are going through the carpet.
    I hope it wont do permanent damage.
    Tapesh
  • Loud & Clear
    Loud & Clear Posts: 1,538
    edited January 2004
    I am also sacred.
    Two Channel Setup:
    Speakers: Wharfedale Opus 2-3
    Integrated Amp: Krell S-300i
    DAC: Arcam irDac
    Source: iMac
    Remote Control: iPad Mini
    3.2 Home Theater Setup:
    Fronts: Klipsch RP-160M
    Center: Klipsch RP-160M
    Subwoofer: SVS PB12NSD (X 2)
    AVR: Yamaha Aventage RX-A2030
    Blu Ray: Sony BDP-S790
    TV Source: DirecTV Genie
  • ntculenuff
    ntculenuff Posts: 1,146
    edited January 2004
    had too spike my subs to my hardwood floors, damn things kept walking around on me:p
    Speakers:
    Definitive BP7001sc mains
    Definitive C/L/R 3000 center
    Polk RT800i's rears
    Definitive supercube I Sub
    Audio:
    Onkyo TX-NR3010
    Emotiva XPA five Gen 3
    OPPO BDP-103 CD, SACD, DVD-A
    Video:
    Panasonic TC-P65ZT60
    OPPO BDP-103 Bluray
    Directv x's 2
