whats the difference between monitor 10a and 10b?
djperez81
i was wondering whats the difference between the monitor 10a and the 10b's?
I was looking at a pair of 10a's on CL.
http://tampa.craigslist.org/pnl/ele/2035320162.html
why are one of the tweeters different color than the other? and what do you guys think about the price? Thanks
Music doesn't lie. If there is something to be changed in this world, then it can only happen through music.
-Jimi Hendrix
-Jimi Hendrix
Post edited by djperez81 on
deleted5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
Surround: Monitor 10B
PSW10 subwoofer
Onkyo PR-SC886P Pre/Pro
NAD T955 5 channel power amplifier
Technics SL-1710 MK2 turntable
Audio-Technica AT14Sa cartridge
Parasound P3 pre-amp
Oppo BDP-103 Blu-Ray
2014 MacBook Pro 2.8 GHz
2.0 Office System:
Monitor 10A (Peerless)
Outlaw 1050 receiver
Parasound HCA-1000A power amp
MacPro -
Monitor 10A usually has a Peerless tweeter. I can't tell from the pictures whether the dark tweeter is a Peerless. Monitor 10B has a SL-1000 (bright brushed steel face like the left speaker) or SL-2000 tweeter. So if these Monitors are truly 10As then the SL-1000 is probably the wrong replacement. It will take more investigation to sort this out. I paid $75 for a nice pair of Monitor 10As with Peerless tweeters, so $130 for a mismatched set is too much.
Jim5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
PSW10 subwoofer
2.0 Office System:
MacPro -
well I actually think they are 10b, at least looking at the drivers and cabinets. they have the beveled faces and they do not have the masonite rings around the drivers. My best guess is the SL1000 is actually the 'replacement' tweeter. It is hard to tell if the black tweeter is.
that being said, price is a bit high, given you will have to replace the tweeter (whichever is the right one) I would probably offer around $75.
good luck -
Are you sure they are beveled?? I thought when they did that they went to full length grills. Those are either late 1983 10As or early 1984 10Bs polk switched cabinets in 1983 to the short grill. if you knew aserial number it may help
10As 6500s with us made Peerless marked 5514____
Early 10Bs 6600X or 6501s with SL 1000s
Crossovers are the same.
keith -
ok thanks for the info guysMusic doesn't lie. If there is something to be changed in this world, then it can only happen through music.
-Jimi Hendrix -
Your probally right Keith...alittle hard to tell on those tiny pics, but once I blew one up they are square cabinets...still would need to replace one of the tweeters.
Some later 10A's had sl1000's instead of peerless. These are mismatched and I wouldn't give him more than $75 for the pair.
Lineage
Monitor or Model 10
Monitor 10A
Monitor 10B
Monitor 10C
Monitor 10 series II"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
Good job Brock, you can count and know your alphabet
As stated, you can find a pair of 10A with Peerless or SL1000.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
I've sold off all of my older 10B's, but I did not know that A's put the polk logo below the grill...though I did see a reference the other day to a short grill 10A. Also my older 10B's had a cutout area between the mids....
