HDMI issue
Willow
Willow Posts: 11,311
I have my ps3 hooked up via HDMI to the TV. Sometimes the screen will just black out, then sometimes it comes back other times I have to go fiddle around with the cable but it's always in and nice and tight. Is this a handshake issue? Then other times there are no issues we can use the ps3 for a long time and nothing.
Post edited by Willow on
  • nguyendot
    nguyendot Posts: 3,594
    edited November 2010
    Yes usually that is a handshake issue. You basically have to go through the process of elimination:
    1) try another cable
    2) try another TV
    3) if possible, try another PS3
    4) update the firmware on the PS3
    5) update the firmware on your tv, if possible
    I had this issue with my PS3 for a while, turned out it was a crappy HDMI cable - I replaced it with a spare and the problems went away. Oddly enough the crap HDMI cable works on another tv with no issues...
    Main Surround -
