Model S6
NeilGabriel
NeilGabriel Posts: 1,487
edited November 2010 in Vintage Speakers
Someone near me is trying hard to sell a pair of S6's....I know nothing about this line of Polks, but I am trying to get in some smaller speakers for some of my bigger monitors.
How do these compare, say to a Monitor 5 or 7? Thanks.
ng
Post edited by NeilGabriel on
  • stubby
    stubby Posts: 723
    I saw those, Mike. Pretty nice price, but like you, I have never heard any of the S series. I would think they should sound at least as good as the Monitors. I remember them getting nice reviews in the audio press.
    stubby
    SRS 3.1TL
    Harman Kardon Citation 5.1
    Anthem AVM2
  • NeilGabriel
    The owner, who did not sound real knowledgeable, referred to them as having foam surrounds....I will double check the Polk page, which they have for these speakers. I would think they would be rubber. I think I will pick them up out of curiosity and for some variety.
    AGAIN, ANYONE THIS OR OTHERS IN THE THIS S SERIES?
    The S6 is just a tad shorter than the 5, about the same width and not as deep. Shows a real deep end for a small speaker....I need tofind the specs for my PSB 300....probably not that low.
    Paul, I will try to pick up and you can get over and listen to them.
  • agfrost
    agfrost Posts: 2,469
    I believe that cabinet construction is considered a weak point in the S series.
    Link to specs and manual pdf:
    http://www.polkaudio.com/homeaudio/specs/recent/s6/
    Price isn't bad!
    Jay
  • cubdog
    cubdog Posts: 835
    I have a pair of S8. They sound surprisingly good. The build quality is below the norm for Polk however. If they are cheap give them a try.
    cubdog
    Shuguang Classic S8MK
    Emotiva XDA-2
    Bel Canto M300 mono blocks
    Bel Canto DAC 1.5
    Squeezebox Touch
    Sony SS-M7
    A/D/S L710
  • S6? I am listening to a pair now and they really shine with older Tim Buckley of Antony and the Johnsons. But . . . Frankly, the Polk Monitor 7 is hard to beat. With a good analogue source and Dynaco Stereo 70, it is among my favorite speakers in terms of musical enjoyment. I have heard lots of newer and more expensive loudspeakers from Polk including the bargain S6. As a rule they are all nice, something along the lines of the better Boston Acoustics. But only the original Monitor 7 is in the same league as the best Mirage and Design Acoustics vintage models. Let's be clear. S6 are fine, smooth, enjoyable, a bit restrained and understated. Bass is not bloated. And sounds a bit more natural than the Monitor 7. But S6 have little magic in them. Nothing really stands out as incredible the way that a really great speaker will just stun you from time to time. With great virtues one often also get great flaws. Polk S6 have neither.
  • Well stated! Welcome to the forum!
  • skrol
    skrol Posts: 3,452
    I have a pair of S6 (cap upgrade), Monitor 5A (Peerless) and Monitor 5B (RD0194 upgrade, XO upgrade). MitchLee describes them well. The S6 build quality is sub-par compared to the Monitors that they replaced but they are a nice pleasant sounding speaker, nothing exaggerated. Between the Monitor 5B and the S6 soundwise, I have a hard time determining which I prefer. The Monitor has more of the classic Polk sound and the S6 slightly more refined.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • skrol
    skrol Posts: 3,452
    edited September 2022
    By the way, the surrounds on the S series are rubber, not foam.
    Stan
    Main 2ch:
    HT:
    Other stuff:
