Is this stand good for Monitor 40s?
I was considering purchasing these stands
Pangea Audio - LS02 - Speaker Stand
for my Polk Monitor 40 speakers. I wanted to know if these would work well for the 40s. One of the reasons I like them are the triangle bases so I can work these into the corner of the room.
I have two Monitor 70s for my front and a CS2 for my center. If these are good stands for my 40s can someone also give me a recommendation for how tall I should order these stands. I can't decide between 28'' and 32'', but I'm not sure if this would be off. I'm trying to keep in mind how tall the Monitor 40s are.
Post edited by ka2lu on
hey....i have my Monitor 40 rears on these in the 29" height and they are pretty much dead on with my ear level on my couch. I think your best bet is to take some measurements and see what height you would need. I'm not sure if it'd be better to err on the side of higher or lower for surrounds.
also, if you don't get a set of stands with bigger top plates, you should definitely consider some blue-tack or velcro for added stability
