B & K Ref 2220
rdb2001
I just received this amp today. Bought it used off agon. I really think something is wrong with the amp. I have to turn it to just about 0 on my pre/pro to get moderate volume. I have a B & K Ref 7250 also and when I hook my fronts back to it all is better. I think there is a serious problem with the 2220. I have emailed the seller. Your thoughts?
Post edited by rdb2001 on
Nevermind. Seller Contacted me. Realized the balanced inputs was selected and I am using RCAs. Problem solved. Mods you can close this thread.
You might feel silly, but those types of problems are so much easier on the wallet. How do you like it so far?Polk Audio SDA SRS 2.3TL
Parasound Halo A21
Parasound Halo P3
Home theater
Polk LSiM 707, 706c, 703, 705
Polk Blackstone TL3 for height
SVS PB12-ISD Sub
Denon AVR-X6400h
Parasound Halo A51
LG OLED65B7A
Sony UBPX800
Logitech Harmony Elite
PC LSiM 703
Spare LSIM 702 and 706c
Home Theater #2
Polk Audio LS70, CS350LS, LSF/X, S4
Onkyo TX-NR808 -
It is a nice amp. It is definitely an upgrade from the adcom 555 II I had before this. I have only had one day with it and so far like what I am hearing. It has goobs of power and makes my logans sing.
