B & K Ref 2220
rdb2001
rdb2001 Posts: 791
edited October 2010 in Electronics
I just received this amp today. Bought it used off agon. I really think something is wrong with the amp. I have to turn it to just about 0 on my pre/pro to get moderate volume. I have a B & K Ref 7250 also and when I hook my fronts back to it all is better. I think there is a serious problem with the 2220. I have emailed the seller. Your thoughts?
Post edited by rdb2001 on
  • rdb2001
    rdb2001 Posts: 791
    edited October 2010
    Nevermind. Seller Contacted me. Realized the balanced inputs was selected and I am using RCAs. Problem solved. Mods you can close this thread.
  • fishbones
    fishbones Posts: 947
    edited October 2010
    <chuckling>
    I've done that before with my B&K.
  • Earthy
    Earthy Posts: 488
    edited October 2010
    You might feel silly, but those types of problems are so much easier on the wallet. How do you like it so far?
    Polk Audio SDA SRS 2.3TL
    Parasound Halo A21
    Parasound Halo P3
    Home theater
    Polk LSiM 707, 706c, 703, 705
    Polk Blackstone TL3 for height
    SVS PB12-ISD Sub
    Denon AVR-X6400h
    Parasound Halo A51
    LG OLED65B7A
    Sony UBPX800
    Logitech Harmony Elite
    PC LSiM 703
    Spare LSIM 702 and 706c
    Home Theater #2
    Polk Audio LS70, CS350LS, LSF/X, S4
    Onkyo TX-NR808
  • rdb2001
    rdb2001 Posts: 791
    edited October 2010
    Earthy wrote: »
    It is a nice amp. It is definitely an upgrade from the adcom 555 II I had before this. I have only had one day with it and so far like what I am hearing. It has goobs of power and makes my logans sing.
