just picked up a cs2
:Djust won a cs2 from polk audio direct for 72 dollars plus 20 for shipping :Dwill i see a big difference from my cs1
Budget 5.1 H.T. Set Up
HK avr 247 - Adcom GFA-7605Mirage Bps 150i powered sub - 40"Samsung LCD ln40c530 - Sony Blu Ray Player BDP-S370 - Comcast digital hd box(motorola dcx3400)
Monoprice Premium Interconnects Monoprice Ultra Slim HDMI w/Redmere
Custom Jumpers
Post edited by K-daugh on
Anybody .....come on guys what are the benefits of a cs2 over a cs1....I know a lot of polkies are running cs2 .....advice thoughts comments whatever.....Budget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
- Belkin PF60 Power Conditioner - Cs2 center channel - Monitor 60's fronts - Monitor 30's rears
-Knukonceptz Kord 10 Gauge Speaker Wire - Nakamichi Banana Plugs
Custom Jumpers -
I'm gonna say the bigger the better for a center channel unless i am wrong.I mean after all,isn't the center one of the most important speakers since the dialog comes from there?Living Room Monitor 60's*CS2*FXi A6's*VSX 21txh*BD-P1590
Spare Room RTi A7*CSi A6*FXi A4's*Epik Legend*BDP-05fd*DVL-919 Laserdisc/DVD player -
What are your front speakers? We need a little more info to give an opinion.
I would think you can get more out of the CS2. More sound, use more wattage. More is better. -
i havent heard a cs1 but my cs2 is performing pretty good for me.Music doesn't lie. If there is something to be changed in this world, then it can only happen through music.
-Jimi Hendrix -
fronts are monitor 60's backs are monitor 30'sBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
Should make a noticeable difference. I run a CS2 with M-70s up front and M-30s in the back...couldn't be happier. CS2...louder, fuller, and even a bit more detail--particularly good on dialog. You'll be happy. And the HK will give you a bit more warmth....I had to tweak the CS2 on the Monster Onkyo I run--set it back -3db less than the fronts and trim the top end a little.
Enjoy!
beautiful ......now the waiting game polk generally ships pretty quick thoughBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
Enjoy!
cnh
how are those seventies treating yaBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
I really like the 70s...especially in my HT. As Doro sometimes says...HT is easy...or it's not as difficult to get right as 2 channel. In my room with the TX-SR 805 Onkyo (a medium-sized room), and a 300 watt RMS 12" sub. Well, I don't really need to worry about DVDs and Blu-rays for a while.
The room shakes, the lighting fixtures rattle, and the boom drives through the ceiling into my wife's office upstairs. I could upgrade, of course. But why bother?
Now in the two channel...I'm still tweaking, buying, switching out, etc.
I'm sure with that HK. Things sound pretty good in your house as well.
yes very good once the new center gets put in place things will sound awesome ....i was blown away the first time i heard the hk ,not ever listening to one prior.....i grew up on a cheap sony ....so this was like a whole new world ......still tweaking the settings here and there but overall im thrilled.....50 watts per channel and i still dont need to turn it up past -35 on tv viewing the loudest i had this thing was -20.....also just got my sub all dialed in a couple weeks ago what a world of difference that made.....:biggrin:im loven life right now.....:biggrin: need a 3 or a 5 channel amp though something that sounds as good if not better than the hk :eek:I really like the 70s...especially in my HT. As Doro sometimes says...HT is easy...or it's not as difficult to get right as 2 channel. In my room with the TX-SR 805 Onkyo (a medium-sized room), and a 300 watt RMS 12" sub. Well, I don't really need to worry about DVDs and Blu-rays for a while.
cnhBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
The advantages should be obvious really. It's bigger.
This equals lower bass extension and less stress across all of the low end in general. Smoother midrange due to being able to produce the low end with less effort. Bigger overall image and better blending with the front L/R due to the bigger size.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
comfortablycurt wrote: »The advantages should be obvious really. It's bigger.
good point..... hoping the wife doesn't notice the size difference....trying to pull the ole switcharoo!!!!!!!:biggrin:Budget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
Front Monitor 60's, rear 30's, and CS2 center ? Enjoy.
HT is easier, as Doro says, but a little more power will help out your Monitors Although a 50 w/channel HK is an honest 50 watts; you shouldn't suffer too much.
BTW, if your wife notices the difference between the C1 and C2 (and she will), just tell her "Oh, I got a bigger speaker grill".
.....which is true.
........ kind of. :redface:Sal Palooza -
mrbigbluelight wrote: »Front Monitor 60's, rear 30's, and CS2 center ? Enjoy.
haha yeah thats a good one.....she may notice she doesnt pay much attention to that stuff though.....but yeah it is considerably bigger.....btw was that comment about my speakers good or bad ....?Budget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
so i got the cs2 on friday and installed it when the wifey was out.....hehhehheehhe.....she doesnt even know ....hahaha.....this thing sounds great much better than the cs1 much more clear and crisp.....not bad for a grand total of ninety dollars from polk direct .....shipping included in that number......but yeah im very happy i noticed i have had my avr lik 5-8 db lower listening levels and havent even noticed until today......even that being said it blends with the fronts awesome......do you guys know anyone who drills two holes in a brand new speaker for mounting purposes that would be me......dont be alarmed i am a carpenter and a good one by trade.....1/8 " hole on the outside edge of either side of the speaker about 3" from the front and 3/8"in from the side.....this is the top of the cabinet we are talking about because it is screwed to the body side of a shelf......lol i wouldnt do it if i didnt have too but hey if your gonna do it then do it right......Budget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers
