Psw650 Problem
TORIPOLLO
Hi, I'm the Polkaudio psw650 subwoofer owner. The sound is fine but until 20 or 30 minutes in use with louder or softer volume, the bass amplifier turn off constantly with 30 seconds intervals. The green lgth in the front is pop up constantly.
Best Regard
Best Regard
Post edited by TORIPOLLO on
Are you using a single line input? If yes, try a Y splitter doubling the input. This should reduce the shutdowns at low level.
Note: With the input doubled, you will need to reduce the sub's amp setting to rebalance it with the rest of your speakers.
... and welcome to the Club...
More later,
Tour...
Vox Copuli
I would like to make a request to Polk asking the psw650 service manual, I think is our right like costumer and owner knows what are inside the product, if i'd want to make a replace or repair.
Thank You -
Tour,
You will probably need to type it out as if you were saying it with a entire bean burrito shoved in your mouth. THEN maybe it can be understood.
Cheers,
Jamie Von PimperneldtCheck your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
