Can you use an integrated amp as an amp?
polkfarmboy
polkfarmboy Posts: 5,703
edited October 2010 in DIY, Mods & Tweaks
The question sounds so dumb
Can I use my tube integrated as an amp with my receiver via the preouts
Post edited by polkfarmboy on
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited October 2010
    While not ideal, sure you can. You'll have to tweak the volume settings on the integrated, contrary to popular belief, you can overdriver line voltage, but it can work, and work well. It really comes down to input impedance on your integrated, and output impedance (and voltage) on your receiver.
    Cheers,
    Russ
  • thuffman03
    thuffman03 Posts: 1,325
    edited October 2010
    I have seen on some that there is a bypass inputs on the back that will allow you to do this.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • polkfarmboy
    edited October 2010
    Well this sounds like good news
    I may try putting my pioneer elite on stereo and pump some 2 channel stereo into it from a digital source like pandora via hdmi
    This method should make it easier to wait on a dac because the receiver will be doing the conversion and putting it into analog through my integrated tube amp
    I will try giving this a blast tomorrow .Before I was running a 6.5 lead splitting it into rca from my laptop into the tube and it did not sound good
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited October 2010
    Many integrateds have preamp outputs and power amp inputs, with jumper bars in between the two. If yours is setup like this, you should be able to just remove the jumpers and connect your receivers preouts into the integrateds power amp inputs.
    You could also do vice-versa, and use the integrated as a preamp by connecting it's preamp outputs to an external power amp.
    What integrated are you asking about?
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • polkfarmboy
    edited October 2010
    My integrated tube amp does not have anything like you mention curt
    Its a yaqin mc10l ...pretty basic stuff with just 4 rca inputs for cd ,tape,dvd and tuner
    My receiver has pre outs so I will just hook up the L/R ch to the tube integrated
    heiney9 Posts: 25,546
    edited October 2010
    Unless you have a very high dollar tube integrated this feature is not common on tube integrated's.
    edited October 2010
    IMO, I wouldn't bother with the hassle as you won't realize much, if any improvement. Why are you wanting to do this?
  • polkfarmboy
    edited October 2010
    heiney9 wrote: »
    I dont have a dac so the receiver could act as one
  • Bobsama
    Bobsama Posts: 526
    edited October 2010
    heiney9 wrote: »
    I know most old Pioneer's (silverface) would use jumpers. Newer int.amps (like McIntosh's) also often have the option.
    polkaudio Monitor 5 Series II
    polkaudio SDA-1 (with the SL1000)
    TEAC AG-H300 MK III stereo receiver
    beyerdynamic DT-880 Premium (600 Ω) headphones
    SENNHEISER HD-555 headphones
    Little Dot MK IV tube headphone amp
    Little Dot DAC_I balanced D/A converter
    edited October 2010
    Bobsama wrote: »
    When did Pioneer make an integrated tube amp? For the price of the MC's tube integrated's I'd expect them to have this feature on some models.
  • Face
    Face Posts: 14,340
    edited October 2010
    Ayon offers that feature on some of their tube integrateds. ;)
  • FTGV
    FTGV Posts: 3,650
    edited October 2010
    Instead of using the pre outs of the reciever you could use its tape monitor or record out thus bypassing its(redundant) preamp stage.Since the level of the tape monitor output is non adjustable volume would be controlled by the integrated.
  • dorokusai
    dorokusai Posts: 25,576
    edited October 2010
    heiney9 wrote: »
    That's what I've noticed as even the Ayre C5 we used at CAA didn't have pre-outs. They're certainly out there but I'd say 50% of what I've used didn't have them.
  • dorokusai
    edited October 2010
    FTGV wrote: »
    I wouldn't suggest doing that as a generic rule as the tape loop or record out could be designed drastically different between manufacturers. You should check the spec's before doing something like that at the very least.
  • FTGV
    FTGV Posts: 3,650
    edited October 2010
    Tape monitor/recording outputs are usually just buffered direct feeds from the source component.
  • dorokusai
    edited October 2010
    I'm aware of what they are, thanks.
  • TECHNOKID
    TECHNOKID Posts: 4,298
    edited October 2010
    FTGV wrote: »
    dorokusai wrote: »
    I agree with Doro and...
    FTGV wrote: »
    Exactly and they must preferably go through a pre-amp of some sort as the signal is lower at that stage, noise could be present and the amp would need to be pushed at higher levels in order to compensate for poor lower input.
    dorokusai wrote: »
    Aren't you happy to still be able to learn at your age :D:p
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
  • FTGV
    FTGV Posts: 3,650
    edited October 2010
    dorokusai wrote: »
    OK other than maybe only a unity gain buffer stage if the signal routed to the recording outputs is not being altered in anyway(no gain,EQ etc.)theN why not do it?what do you think are the comprimises with this simpler signal path approach?
  • dorokusai
    edited October 2010
    I'm not questioning the idea of the simpler path but not every manufacturer uses the same theory and signal path. It's not a standard. The voltages and/or gain could vary and depending on your loudspeaker at any given time, it could be a serious issue in the chain of gear. Just because it's available doesn't mean it's usable.
  • FTGV
    FTGV Posts: 3,650
    edited October 2010
    TECHNOKID wrote: »
    A tape output only needs unity gain buffering(no gain) to isolate the output from the loading effects of a connected recorder that is shut off.Some older units simply used resistors instead of an opamp for the purpose.
  • megasat16
    megasat16 Posts: 3,521
    edited October 2010
    dorokusai wrote: »
    You can count on my wallet if anything broken due to the use of Line level (recording) Tape Output, I will fix it or pay for it. Well, exception applies if your amp is under 100 ohms input impedance.
    Just saying it's quite safe to use. :D
    The downside is as Fred mentioned before, there is no preamp control over it and sometimes, signal may be attenuated in some designs.
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • dorokusai
    edited October 2010
    It wasn't so much about the impossible than simply about knowing what you're doing before you start throwing interconnects onto outputs you never used in your entire audio life. Not every piece of gear is designed the same way.
    Go for it, it's not my gear but I've never....ever, had a need to utilize tape outputs on any of the 100 or so rigs I've maybe owned. YMMV. I'll just go back to my boombox.
  • FTGV
    FTGV Posts: 3,650
    edited October 2010
    dorokusai wrote: »
    The voltages/and or gain could vary depending on your loudspeaker at any given time, it could be a serious issue in the chain of gear. Just because it's available doesn't mean it's usable.
    You must have missed the part where I said the integrated amps volume control would be what you set the levels with.In this way with the tape out from the reciever hooked into an aux input on the integrated would work like any other source.Anyway IMO it's somthing the OP could try,no harm will be done.
  • dorokusai
    edited October 2010
    No, I didn't miss it. I understand what you're saying.
  • megasat16
    edited October 2010
    dorokusai wrote: »
    I agree. But the question is more about the SQ if Tape output is used. I guess that's why I avoided Integrated Units as much as possible.
    Well, your boombox can play louder than my boombox?
  • dorokusai
    edited October 2010
    :D I wish.
  • FTGV
    FTGV Posts: 3,650
    edited October 2010
    megasat16 wrote: »
    My Bose Wave Radio trumps whatever you might have James.;):p
  • megasat16
    edited October 2010
    dorokusai wrote: »
    :D I wish.
    :D My bluffing works?
    FTGV wrote: »
    Friends don't let friends listen to Bose Wave Radio. I'll send over my boombox to you next time. :D:p
  • FTGV
    FTGV Posts: 3,650
    edited October 2010
    megasat16 wrote: »
    Friends don't let friends listen to Bose Wave Radio.:D :p
    :(Even if it has the Clarity Cap upgrade?:D
  • megasat16
    edited October 2010
    Oh, crap! All you BOSE owners are filthy RICH!
    I can only dream of putting a Clarity cap in my boombox. :D
