Coupling cap question.
heiney9
I have a Norh SE-9 tube amp. The input tube coupling caps are .25uF 200V WIMA's (those red square caps). I read over at Audiocircle of someone replacing them with .33uF 450V Auricaps. I really like Auricaps.
My question is what effect will the extra capacitance have in the circuit? Auricap also make a .22uF 450V but that is a lesser value than the stock. I thought it might be better to go a bit larger. Obviously the voltage rating of the Auricaps is just fine.
Thoughts, comments, idea's. Having second thoughts going with something that much larger.
P.s. I already have the .33uF Auricaps
Post edited by heiney9 on
The larger cap will mean the low frequency roll off will start slightly lower.If you know the impedance the cap is looking into it 's easy to calculate the change.http://www.muzique.com/schem/filter.htm
More bass but it would be below below audibility assuming high enough input impedance. Using 100k ohms as an example .33uf would result in a corner frequency of 4.8 hz and with .22uf it would be 7.2hz.So both caps would be usable with the example input impedance of 100k.
Thanks guys, I don't have a schematic, but I can post some high rez pics where the caps are. But it sounds like it'll be alright to use a value close but not exact.
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul!
