Coupling cap question.
heiney9
heiney9 Posts: 25,724
edited October 2010 in DIY, Mods & Tweaks
I have a Norh SE-9 tube amp. The input tube coupling caps are .25uF 200V WIMA's (those red square caps). I read over at Audiocircle of someone replacing them with .33uF 450V Auricaps. I really like Auricaps.
My question is what effect will the extra capacitance have in the circuit? Auricap also make a .22uF 450V but that is a lesser value than the stock. I thought it might be better to go a bit larger. Obviously the voltage rating of the Auricaps is just fine.
Thoughts, comments, idea's. Having second thoughts going with something that much larger.
P.s. I already have the .33uF Auricaps
  • FTGV
    FTGV Posts: 3,650
    edited October 2010
    The larger cap will mean the low frequency roll off will start slightly lower.If you know the impedance the cap is looking into it 's easy to calculate the change.http://www.muzique.com/schem/filter.htm
  • schwarcw
    schwarcw Posts: 7,360
    edited October 2010
    Maybe a little more bass?
    Carl
  • FTGV
    FTGV Posts: 3,650
    edited October 2010
    More bass but it would be below below audibility assuming high enough input impedance. Using 100k ohms as an example .33uf would result in a corner frequency of 4.8 hz and with .22uf it would be 7.2hz.So both caps would be usable with the example input impedance of 100k.
    edited October 2010
    Thanks guys, I don't have a schematic, but I can post some high rez pics where the caps are. But it sounds like it'll be alright to use a value close but not exact.
