A little paranoid...
Solidate
Solidate Posts: 16
edited October 2010 in Speakers
I need some peace of mind...
I'm running two M60's, CS1, M30's, and a BIC F12.
Crossover is at 60 for 60's and 80 for the rest.
My receiver is a Denon 1611 75x7 WPC
Will my speakers live long enough if the maximum volume I crank them up to is 0 dB? (I believe that's 80 dB)
Thanks!
Post edited by Solidate on
  • grimmace19
    grimmace19 Posts: 1,429
    edited October 2010
    I personally wouldn't venture that high on the volume know even with a power amp. To me there isn't a need to go past -20db. There is a difference between rated wated (75x7) and actual output when you have more channels running. Once you get past feeding them clean power you will most likely blow something if you keep pushing them.
  • HTguru1982
    HTguru1982 Posts: 1,066
    edited October 2010
    No, you'll fry something with volume that high. -20db is as loud as I would go. I've had Denon receivers in the past and anything past -30db was too loud for me. If you add an external amp(assuming your receiver has preouts) then you'll probably be fine.
    Display: Sony 42" LCD
    Sources: Harman Kardon DVD-27,
    Panasonic DMP-BDT110 blu ray player
    AVR: Sony STR-DA2400ES
    Amps: Sonance Sonamp 260(fronts),
    Kenwood KM-894(surrounds)
    Fronts: NHT 2.5
    Center: NHT VS-1.2A
    Surrounds: NHT Super One
    Subwoofer: SVS PB10-ISD
    F1nut Posts: 51,999
    edited October 2010
    80 dB is not very loud.
    edited October 2010
    When he says he cranks them up to 0...I believe he means on the volume dial. If so,yeah,your stretching it there pal. In surround mode your probably only feeding them 40 watts,so your pushing it. Upgrade the receiver or find one with preouts to add an amp later down the road. Or the obvious, keep your peanut butter and jelly fingers off the volume dial my man.
  • Solidate
    Solidate Posts: 16
    edited October 2010
    So -20 dB would keep it safe?
    I only use 0 dB when I play a movie or listen to classical music. So I don't mind lowering it.
    Oh well, good thing that I know this now.
    Thank you for the input!
    I will go ahead and set the limit -20 dB.
  • BlueFox
    BlueFox Posts: 15,250
    edited October 2010
    How many times does it need to be mentioned the volume settings on an AVR mean nothing. My AVR goes to +11db.
    Does it sound like crap when loud? If so turn it down. Is the volume all the way, or almost all the way, up? If so it is to loud for the AVR. Turn it down.
    Get a SPL meter and measure how loud it is at various volume settings. If you have a low end AVR then playing it all the way up will more than likely damage either the speakers, the AVR, your ears, or all three.
  • cnoat
    cnoat Posts: 315
    edited October 2010
    Can anyone say clip?
    Parasound Avc-1800
    Mains-Rti 12 -Parasound 1500a
    Center-Csi5-Parasound 1000a
    Rears-Rti 8-Parasound 750a
    Sub SVS Ultra Tv 12
    Diamondback and King Cobra IC's
    AQ T4 SC
  • Solidate
    Solidate Posts: 16
    edited October 2010
    cnoat wrote: »
    Well, I did hear faint pops at that volume...
  • Solidate
    Solidate Posts: 16
    edited October 2010
    BlueFox wrote: »
    It actually sounds clear at 80 dB on my AVR. I can hear hissing though...
  • BlueFox
    edited October 2010
    Solidate wrote: »
    Hissing over the music/movie, or with no input and cranked up? Hissing over the audio is a bad sign. Some hissing while cranked up is 'normal' for a lot of gear.
    I had an AVR go bad and start hissing. I was watching a movie one night, and I thought it was raining out. A little later I realized the AVR was doing it, and off to the repair center it went.
  • Solidate
    Solidate Posts: 16
    edited October 2010
    BlueFox wrote: »
    At 0 dB it hisses when I play something and then pause it. Otherwise I can't tell if it's hissing while the movie is going. At -20 and lower there is no hiss at all.
    I really hope I didn't mess anything up. Only had this system for 2 weeks. Would be a shame to see it die on me.
  • whgarrett1394
    whgarrett1394 Posts: 217
    edited October 2010
    These go to eleven!:D
    KEF Q50 mains, M&K center, Boston Acoustics surround, Marantz SR6007 pre, Emotiva UPA-700, Pioneer DV-46AV, Samsung BD-j7500, Sunfire HRS12 subwoofer
  • lightman1
    lightman1 Posts: 10,797
    edited October 2010
    Distortion has been the death of many a speaker.
  • B Run
    B Run Posts: 1,888
    edited October 2010
    I had the exact same setup m60's, cs1, m30's but I had the Denon 1909 with 90 watts per channel, and I clipped my tweeter in the cs1. I noticed when I used a Yamaha rxv1800 with 130 watts X 7 at .04% distortion I could crank it up MUCH louder without even a hint of distortion, so be careful with the 1611.
  • Solidate
    Solidate Posts: 16
    edited October 2010
    Well if I don't go past -20 dB on my AVR I should be fine I guess. It says master volume is at -40 dB so... I'll just hope they last. At 1k it's an investment lol
  • PrazVT
    PrazVT Posts: 1,607
    edited October 2010
    Hmm interesting. For a while, I was under the impression that '0' was reference volume (ie THX reference), but now I see that is probably not accurate.
    I do tend to up the volume into the teens (-16'ish dB) for a few min when watching 5.1 movies if there is a quiet dialog section..but otherwise, in the low -20s. I've never heard any hissing though.
    Same with music (just the RTi A7s w/ the Parasound amp)...mid to low -20s, -18 on occasion. mid to low -20s max for 5.1 DTS CDs.
    I'm sure the necessity to turn the volume up depends on the room acoustics, ambient noise, etc. But is turning up the volume more dangerous for the electronics if the amp / receiver are underpowered?
    EDIT: Perhaps my situation is similar to B Run's. Denon 125w x 7 @ .05 powering just the surrounds, Onkyo 105w x 2 powering the center, and the Parasound 250w x 2 powering the mains - perhaps a bit more headroom?
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
  • B Run
    B Run Posts: 1,888
    edited October 2010
    I think the distortion levels play a huge factor in how loud you can turn it up, once you turn it up and start getting distortion that's how you clip a tweeter. Honestly though I always listen to music on my system at 0, and usually watch movies somewhere between -10 and 0, and I never hear any distortion and the receiver never gets hot or struggles. I'm sure having an external amp would help a lot, and it's definitely on my list.
  • Solidate
    Solidate Posts: 16
    edited October 2010
    B Run wrote: »
    Personally I can't tell if there's distortion at 0 dB.
    Sometimes when listening to music I would hear a faint pop. Nothing overpowering though. Might be the mp3.
    I watched how to train your dragon at 0dB and it sounded clean to me.
    edited October 2010
    Rarely get above -20 on a Denon AVR? The upper limit is +18 the lower -80. I've often run above -20, as F1nut suggests above, that's not that loud for HT. I remember seeing systems hooked to Denon 988s (2808) in Big Box stores that needed to be at -8 so you get get some 'realism' from the Video disc and that was on a KEF satellite system. You'd be best off getting an SPL meter and checking the Reference levels instead of relying on Denon's numbering scheme.
    Speaker Efficiency is also a consideration here, I'd say. You're probably not going to fry anything at higher than -20 unless the amp clips...which doesn't seem likely considering what speakers you're driving?
    The caveat, is of course, that the 1611 may clip more quickly than a higher model? I own a 280X series and I don't hear any distortion at 0....nothing. It's dead quiet. Though I don't run that high!
    Finally, MP3s are not a good test of clean sound at High Volumes as you seem to surmise.
    cnh
  • jayman_1975
    jayman_1975 Posts: 672
    edited October 2010
    PrazVT wrote: »
    You are right. On a "thx" processor such as my AV9, when i hit 0 it says "REFERENCE" beside it. It's ridiculously loud and i would never watch a movie or listen to music at that level. I used my spl meter and got a level of 105db at -5 volume setting and turned it down before i blew my windows out of my living room. The manual says max volume is +15.
    Onkyo TX NR 5008 modified by The Upgrade Company
    Oppo BDP 93 modified by The Upgrade Company
    Arcam CD37
    Monitor Audio Gold GS 60
    Revolver Audio Music 5 towers.(surround)
    Vandersteen V2W
  • Solidate
    Solidate Posts: 16
    edited October 2010
    Well at 0 dB on the Denon I can only hear a hiss when I pause it. It's not very loud either. I'm actually comfortable at -10 for movies because it's just the right volume for my room. Besides, my speakers are already set at a lower dB because of auto eq. -6 to -8 dB throughout the speakers.
    I'll get an spl just in case though.
    What dB should I be aiming for with it for max allowable volume?
    Since 0 is loud already and seems clean to me... I'd say -10 is the sweet spot.
    VR3 Posts: 29,549
    edited October 2010
    I love watching movies at 0...
    You guys are wimps.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited October 2010
    The volume "level" readout on an AVR is essentially meaningless, and varies greatly from receiver to receiver. If the signal is coming through with no distortion, and no obvious strain on the speakers...such as bottoming out etc...then you should be just fine.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • Solidate
    Solidate Posts: 16
    edited October 2010
    If only I could tell what that sounded like...
    So far the only thing I notice is that my center speaker lacks base in dialogue so it can be a bit harsh. Nothing unbearable though
  • PrazVT
    PrazVT Posts: 1,607
    edited October 2010
    So ultimately, what's the deal? It almost sounds like if you have a lower powered receiver / amp, and you turn the volume up high, there is some risk of damaging something.
    Too much stress on the receiver? Screwy power going to the speakers? Just curious.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
  • comfortablycurt
    edited October 2010
    PrazVT wrote: »
    The problem is, that with lower powered AVR's, they won't be able to supply enough current to generate big dynamics. This causes the speakers themselves to work much harder to attain higher volumes, which can ultimately damage them. This is why higher powered external amps are the best option whenever possible.
  • PrazVT
    PrazVT Posts: 1,607
    edited October 2010
    ie. higher current amps right? Thanks - interesting stuff :)
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
