Proper cleaning
steveinaz
steveinaz Posts: 19,545
edited October 2010 in DIY, Mods & Tweaks
Time and time again I see components with high gloss black, or plastic display faces that look terrible. It's from bad cleaning habits. DO NOT use paper towels and/or cleaning chemicals. Spend the HUGE sum of $7.99, and buy a real chamois. I have cleaned my equipment with one for over 20 years. Everything from HDTV screens to speaker drivers. Hot water and a chamois, well wrung is all you need to keep your investment(s) looking MINTY fresh. Use the chamois ONLY for your equipment. You can cut the chamois in half and double your spending value.
Ask anyone who has bought equipment from me, the display faces look NEW. No swirls, spider-webbing, or scratching. Want to see the horrifying truth? Turn all the lights off and shine a flashlight at an angle at your equipments' display faces---scratches will show if they haven't been cleaned properly.
Post edited by steveinaz on
    F1nut Posts: 51,719
    edited October 2010
    Solid advice, thanks Steve.
  • Face
    Face Posts: 14,340
    edited October 2010
    A damp microfibre cloth also works very well. If the finish is painted, I use turtle wax also. :)
  • K-daugh
    K-daugh Posts: 467
    edited October 2010
    just picked up a three pack of microfiber cloths,a blush brush(wifes idea),and a can of air to clean up my amp now i just need some deoxit ......should i just clean the surfaces i can see or do i need to take some stuff apart....obviously ill take the top of the amp .....do i or dont i go near the circuit board......need some advice (not to take over the thread or anything)cheers...
    Budget 5.1 H.T. Set Up
    HK avr 247 - Adcom GFA-7605:mrgreen::mrgreen: - Belkin PF60 Power Conditioner - Cs2 center channel - Monitor 60's fronts - Monitor 30's rears
    Mirage Bps 150i powered sub - 40"Samsung LCD ln40c530 - Sony Blu Ray Player BDP-S370 - Comcast digital hd box(motorola dcx3400)
    Monoprice Premium Interconnects Monoprice Ultra Slim HDMI w/Redmere:mrgreen: -Knukonceptz Kord 10 Gauge Speaker Wire - Nakamichi Banana Plugs
    Custom Jumpers
  • steveinaz
    edited October 2010
    I've tried micro-fiber, and although they are soft enough for the job, I can never get them wrung enough to not leave a little water smearing behind. YMMV.
    K-
    I would not touch the boards, just use canned air and make sure to let it dry completely as canned air has mositure from condensation.
