Proper cleaning
steveinaz
Time and time again I see components with high gloss black, or plastic display faces that look terrible. It's from bad cleaning habits. DO NOT use paper towels and/or cleaning chemicals. Spend the HUGE sum of $7.99, and buy a real chamois. I have cleaned my equipment with one for over 20 years. Everything from HDTV screens to speaker drivers. Hot water and a chamois, well wrung is all you need to keep your investment(s) looking MINTY fresh. Use the chamois ONLY for your equipment. You can cut the chamois in half and double your spending value.
Ask anyone who has bought equipment from me, the display faces look NEW. No swirls, spider-webbing, or scratching. Want to see the horrifying truth? Turn all the lights off and shine a flashlight at an angle at your equipments' display faces---scratches will show if they haven't been cleaned properly.
Solid advice, thanks Steve.
A damp microfibre cloth also works very well. If the finish is painted, I use turtle wax also.
"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
just picked up a three pack of microfiber cloths,a blush brush(wifes idea),and a can of air to clean up my amp now i just need some deoxit ......should i just clean the surfaces i can see or do i need to take some stuff apart....obviously ill take the top of the amp .....do i or dont i go near the circuit board......need some advice (not to take over the thread or anything)cheers...Budget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
- Belkin PF60 Power Conditioner - Cs2 center channel - Monitor 60's fronts - Monitor 30's rears
Mirage Bps 150i powered sub - 40"Samsung LCD ln40c530 - Sony Blu Ray Player BDP-S370 - Comcast digital hd box(motorola dcx3400)
Monoprice Premium Interconnects Monoprice Ultra Slim HDMI w/Redmere
-Knukonceptz Kord 10 Gauge Speaker Wire - Nakamichi Banana Plugs
Custom Jumpers -
I've tried micro-fiber, and although they are soft enough for the job, I can never get them wrung enough to not leave a little water smearing behind. YMMV.
K-
I would not touch the boards, just use canned air and make sure to let it dry completely as canned air has mositure from condensation.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
