break-intime
leftwinger57
leftwinger57 Posts: 2,917
edited October 2010 in 2 Channel Audio
Hi guys, I'm still pretty new to converting to 2-ch and been seeing the term
breake in time thrown around an awful lot. When it comes to speakers when and how does this happen.I own a pair of refoamed Infinitys and have run them at various levels for all sorts of time periods. My new/old amp the Adcom which is ss so I dom't think this burn in is a factor. This is big on so many sites so it has to hold some credence but to who , but when. With tubes one can say they need to warm up but other gear I don't get it.With me I clunk the h/d Adcom swicth, push theOnkyo pre on button,push the Denon on and away I go without a minute
of time to warm up.I do remember years ago when buying a new car you'd
have to baby it for about500miles. Is this the same theory, if so when do you know youv'e reached optimum performance.......lw
PS May NEW THREAD---when to you invest to re cap amps. With speakers one could see and hear blown surrounds but the internals, how does aguy know to do this kind of work......lw
  • steveinaz
    steveinaz Posts: 19,545
    edited October 2010
    On speakers, the flexing (loosening up) of the surround as well as electrical break-in of cross-over components will affect the final sound. Different speakers take different amount of time to break-in fully, but generally after a month of normal use--they'll be there.
    As to re-capping I have no idea.
  • CTTE
    CTTE Posts: 183
    edited October 2010
    I don't know which Adcom you have, but my gfa555II didn't sound good until it had warmed up for 15-20 minutes. I just left it on all the time when I was using it.
  • ESavinon
    ESavinon Posts: 3,067
    edited October 2010
    My general belief is any audio component will reach it's optimal state after 500 hrs of burn in/use time. This is my opinion based on my experience.
    SRT For Life; SDA Forever!
    The SRT SEISMIC System:
    Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once.
    F1nut Posts: 51,719
    edited October 2010
    To the OP, you are talking about two different things. Burn in/break in occurs when you have a new piece of gear or have replaced certain parts like upgraded crossovers, new drivers, etc.
    Warm up occurs when you turn on a piece of gear.
    In either case, the amount of time will vary. With burn in/break in I would say at least 200 hours or when the sound settles down and you no longer hear changes. With warm up, a few minutes to a few hours.
  • TORI3
    TORI3 Posts: 234
    edited October 2010
    I know there's varying opinions as to whether or not burn-in or break-in exists. I was on the fence until I purchased my little Sunfires a couple of months ago. In all truthfulness they only go down to 90hz, but when I got them bass sounded like someone was tapping their fingers on cardboard.
    After a month or so, they finally opened up with a larger sound stage and a noticeable fullness. In essence, I think it all depends on the type of speakers.
    HT: RTi8s, CSi3, RTi4s, HSU ULS-15, Pioneer Elite VSX-23TXH, Sunfire Cinema Seven.
    2CH: CJ MF2300, Parasound P3, PS Audio DLIII, Wadia 170i, Music Hall Maverick, Sierra-1s, Sunfire HRS8
  • leftwinger57
    edited October 2010
    the amp is an Adcom gfa555 industrial model w/the handles. I've listened to it just after flipping the switch and also later on and I swear I hear not one note of difference. Maybe it's the periferals that I'm using, so on to a better cdp first.The Denon I have is very noisey
    and just maybe it might be the culprit....... Any help would gladly be absorbed. One other thing I do not have a sigle connecter or cords or cords that are dipped in gold......LW
