dolby digital or dts (5-channel)
K-daugh
currently running an hk avr 247 .....wondering whats a better setting to go with dolby digital or dts .....my ipod plays logic 7 which i like .....but mostly for home theatre is dolby digital better or dts
Budget 5.1 H.T. Set Up
HK avr 247 - Adcom GFA-7605Mirage Bps 150i powered sub - 40"Samsung LCD ln40c530 - Sony Blu Ray Player BDP-S370 - Comcast digital hd box(motorola dcx3400)
Monoprice Premium Interconnects Monoprice Ultra Slim HDMI w/Redmere
Custom Jumpers
Post edited by K-daugh on
I have the same thoughts as the post above me. For whatever reason I always start on DTS (if available) and then try the DD.
how about comcast cable viewing???? not sure if dts is offered......Budget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
- Belkin PF60 Power Conditioner - Cs2 center channel - Monitor 60's fronts - Monitor 30's rears
-Knukonceptz Kord 10 Gauge Speaker Wire - Nakamichi Banana Plugs
Custom Jumpers -
i dont if my ears are broken..... or what but i feel i prefer dolby digital.....i dunnoBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
They're the same, but different. Go with whatever your source is encoded in. How are you connecting your iPod? Analog?
mdaudioguy wrote: »They're the same, but different. Go with whatever your source is encoded in. How are you connecting your iPod? Analog?
yeah i got a dual female rca to single male 3.5mm from monoprice....sounds really good......bass is bumping....Budget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
all my cables are monoprice .....just throwing that out there....proud of it tooBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
Ok, try this (from page 45 of your manual):
Those 60's should sound pretty good in this mode for music. IMO, the Logic 7 processing is outstanding for 2-channel stereo movie soundtracks, but sucks for music... but, to each their own. Enjoy.1. Analog Bypass Mode: In this mode, the 2-channel signal is passed
directly to the volume control, without being digitized or undergoing
any processing for bass management or surround sound. The
requirements for selecting analog bypass mode are:
a) The analog audio inputs for the source must be selected. If necessary,
press the Digital Button on the remote and use the ^⁄v
Buttons to make the selection.
b) The tone controls must be disabled by setting TONE MODE to OUT.
Either use the Input Setup menu in the full-OSD system to make
this change, or press the Tone Mode Button on the front panel or
remote and use the / Buttons (^⁄v on the remote) until
the TONE OUT message appears.
c) The Surround Off mode must be selected. The easiest way to
select the Surround Off mode is to press the Stereo Button on the
remote until the Surround Off icon is lit (and the DSP icon is not lit)
in the front-panel display.
wow sounds really good cant really turn it up though my daughter is sleeping in the next room...will do soon though and let you knowBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
thanksBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
ipod I would only play in stereo mode, cable and over air broadcast is all Dolby if it has it.
My pioneer automatically sees what is coming in and switches so i realyl do not mess with it.HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
I have heard that the only difference between Dolby Digital and DTS is that DTS adds +3 db's to the rear channels. Any truth to that?Shawn
AVR: Marantz SR-5011
Center Channel: Polk LsiM706c
Front: Polk LsiM703
Rear: LSI fx
Subwoofer: SVS 20-39pci
DVD Player: Sony PS4 -
stock setting when my source is the cable box is dolby digital as wellBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
i do not have the luxury of a blue ray player yet.......fmlBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
i have an amp and a new sub ahead of the ps3 i want ......lol thats the order of my wish listBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
maybe i should stick the ps3 ahead of the subBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
well my budget was some where around 400 but....... im three weeks out on that......Budget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
so now im kind of in the looking around figuring out what i want stageBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
mdaudioguy wrote: »Ok, try this (from page 45 of your manual):
just tested this out to dave mathews band -crash and various other songs from a few different genres........absolutley stunning .....i love my hk avr 247 best 180 ive ever spent (polk audio ebay) the 60s sound great .....the highs sound crystal clear mids are great bottom end is great.....im a happy camper, cant wait to add an amp....thanks for the great advice.....Budget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
To my ears, DTS usually offers better bass than DD!
I agreeHT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
Most of the time you don't really have a choice... lol. Take whatever the source gives you. If you have a choice - DTS.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
DTS is much better than Dolby Digital. Not just better bass, but everything else is better (Resolution, clarity, etc.etc.)
Greg
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
Greg
Yep..that's what I noticed. -
Greg
headrott is right. If the soundtrack is encoded in DTS and Dolby....In general there is MORE information on DTS version....less compression. You can look up the amount of storage for audio that both use on WIKI. DTS takes up more space. And I too, generally prefer it.
But as far as translating two channel music into surround sound. I find Dolby music II does fine.
