Electronics question
VR3
VR3 Posts: 29,538
edited October 2010 in DIY, Mods & Tweaks
Im not electronics tech but
In my Candela next to the power supply filter caps there are some .1uf capacitors - are these Bypass caps?
It is my understanding I would yield the best results replacing these caps?
Post edited by VR3 on
    F1nut Posts: 51,954
    edited October 2010
    With that value, they have to be bypass caps.
    VR3 Posts: 29,538
    edited October 2010
    Would it benefit me to change these? Changing the filter caps themselves are a no go due to the values of the caps..
    Alex at Odyssey used WIMA for these caps.
    F1nut Posts: 51,954
    edited October 2010
    Changing those caps will result in a slightly different flavor. Whether that is a benefit or not, I can't say.
    VR3 Posts: 29,538
    edited October 2010
    Hmm interesting. Ok....
    I dont know if I would want to change them. Maybe I should stop while I am ahead haha
    Thanks for the help
    F1nut Posts: 51,954
    edited October 2010
    Well, one good thing about caps of that value, most of them are relatively cheap.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited October 2010
    Small cap of value of .01uf to .1uf are used to reduce a high frequency noise which can be on ac line. This noise can be anything from phone extenders to X10 stuff. I not sure if changing them would make any difference at all, I don't think it would be worth the cost to change them.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • Face
    Face Posts: 14,340
    edited October 2010
    Rolling PS bypass caps is a popular tweak: http://jimmyauw.com/?s=bypass
  • Knucklehead
    Knucklehead Posts: 3,602
    edited October 2010
    disneyjoe7 wrote: »
    +1...our ATM's that I work on have the same caps on the high side comms board to filter out electrical noise.
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
    VR3 Posts: 29,538
    edited October 2010
    Hmm
    Im thinking about changing everything circled..
    There are two sand cast resistors - I was thinking about changing them out with Mills, good idea?
    The bottom caps are 1uf Sonicaps - thinking about Clarity Cap MR
    The caps beside the power supply caps are real small and I was thinking Clarity Cap ESA
    Thoughts?
  • disneyjoe7
    edited October 2010
    The bottom caps would make the best improvement to the sound. The power suppy changes I'm not sure if you would make any difference at all.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Face
    Face Posts: 14,340
    edited October 2010
    Whatever you do, change one thing at a time, starting with the coupling caps.
    VR3 Posts: 29,538
    edited October 2010
    Alright...
    I am going to do this -
    But, after all these power cords and my speakers are done. Binding post arrived earlier in the week - but couldnt make it to the post office till today, so should have both done by end of the weekend hopefully.
