Electronics question
VR3
Im not electronics tech but
In my Candela next to the power supply filter caps there are some .1uf capacitors - are these Bypass caps?
It is my understanding I would yield the best results replacing these caps?
With that value, they have to be bypass caps.
Would it benefit me to change these? Changing the filter caps themselves are a no go due to the values of the caps..
Alex at Odyssey used WIMA for these caps.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Changing those caps will result in a slightly different flavor. Whether that is a benefit or not, I can't say.
Hmm interesting. Ok....
I dont know if I would want to change them. Maybe I should stop while I am ahead haha
Thanks for the help- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Well, one good thing about caps of that value, most of them are relatively cheap.
Small cap of value of .01uf to .1uf are used to reduce a high frequency noise which can be on ac line. This noise can be anything from phone extenders to X10 stuff. I not sure if changing them would make any difference at all, I don't think it would be worth the cost to change them.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Rolling PS bypass caps is a popular tweak: http://jimmyauw.com/?s=bypass"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
disneyjoe7 wrote: »Small cap of value of .01uf to .1uf are used to reduce a high frequency noise which can be on ac line. This noise can be anything from phone extenders to X10 stuff. I not sure if changing them would make any difference at all, I don't think it would be worth the cost to change them.
+1...our ATM's that I work on have the same caps on the high side comms board to filter out electrical noise.Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
Hmm
Im thinking about changing everything circled..
There are two sand cast resistors - I was thinking about changing them out with Mills, good idea?
The bottom caps are 1uf Sonicaps - thinking about Clarity Cap MR
The caps beside the power supply caps are real small and I was thinking Clarity Cap ESA
Thoughts?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
The bottom caps would make the best improvement to the sound. The power suppy changes I'm not sure if you would make any difference at all.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Whatever you do, change one thing at a time, starting with the coupling caps."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Alright...
I am going to do this -
But, after all these power cords and my speakers are done. Binding post arrived earlier in the week - but couldnt make it to the post office till today, so should have both done by end of the weekend hopefully.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
