Tube Dampers???
Toolfan66
Toolfan66 Posts: 18,066
edited October 2010 in 2 Channel Audio
Where is and what are good tube Dampers??
I was looking at the ones on Herbies website. Thought I would ask about them before I pulled the trigger.
Thanks.
Post edited by Toolfan66 on
    heiney9 Posts: 25,440
    edited October 2010
    Herbie's are about the best, but they can be pricey. There may be a cheaper alternative that is just as good. Not sure what it is though.
    edited October 2010
    Thanks H9 that's all I really needed to hear. I will just get them coming.
    Did you notice any improvements using them?? Just dampers in general not herbies..
  • thsmith
    thsmith Posts: 6,082
    edited October 2010
    I have tried Herbies and the o rings versions and did not like the results. Seem to take away more than anything. YMMV
    edited October 2010
    I did on marginally microphonic tubes. They are a nice tube accessory/tweak.
  • headrott
    headrott Posts: 5,496
    edited October 2010
    Another vote for Herbies. They are throughout my rig and improved the sound of the tubes dramatically. Highly recommended Larry.
    Greg
  • headrott
    edited October 2010
    thsmith wrote: »
    I can see why it seems they take away from the tube sound. They make the sound more focused and "solid" sounding. The tubes are not as "airy" sounding with as much openness. But, they take away sibilance and dramatically improve detail and imaging (from my experiance anyway).
    Greg
  • Ern Dog
    Ern Dog Posts: 2,237
    edited October 2010
    I use those red O rings on all the tubes in my rig. It sounds tighter and less mushy.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited October 2010
    I use them I dont use them, its tubes baby and its wonderful.
    RT1--Tubes Rule
