TSI vs Monitor series sound question
I'm sure this has been asked. My search skills are lacking so I appologize for asking a question that has been gone over before.
How much (if any) sound difference is there between these two series of speakers? Tsi vs Monitor.
Thinking about getting M60 or 70's, or Tsi 400 or 500's. Monitor series is cheaper, so if not that much of a difference I'll save some coin and get those.
Thanks.
Thanks.
Post edited by Hedco on
Thanks.
The Monitor series was replaced by the TSi series in early 09 I believe. The TSi do sound a little different (I have been told, never heard it but whatever). Save the coin go with the Monitor stuff and drop the extra into a really nice sub."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
There's not too much difference, i'd go Monitor for the price.
+1 for the Monitors. Even with my A7s, the Monitor 70s look very attractive for the $$.Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
..the rest are headphone setups. -
I was happy with my Monitor 60's, I know the 70's will sound even better.
same here, go with the monitorsMarantz SR 7007
polkaudio RTi10
polkaudio CSi A6
polkaudio RTiA3
B&K ST.3140 Power Amplifier
HSU Research VTF2 MK3
Vizio P65-C1
Panasonic 605 blu ray
Onkyo DS-A4 i-pod Dock
Universal Remote
BDI Icon 9429 TV Stand -
i own monitor 60s and 30s ......absolutely love them !!!!!!Budget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
- Belkin PF60 Power Conditioner - Cs2 center channel - Monitor 60's fronts - Monitor 30's rears
Mirage Bps 150i powered sub - 40"Samsung LCD ln40c530 - Sony Blu Ray Player BDP-S370 - Comcast digital hd box(motorola dcx3400)
Monoprice Premium Interconnects Monoprice Ultra Slim HDMI w/Redmere
-Knukonceptz Kord 10 Gauge Speaker Wire - Nakamichi Banana Plugs
Custom Jumpers -
i like your setup how do you like the 40's does 6.1 work for you .....whats it likeBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
You might hear a little difference at the low end since the Monitors have their port on the front and the TSIs have their port on the bottom.
Go with the Monitors...
I tested my Monitor 70's back to back with the TSi 500's and I PREFER the Monitor series.
The TSi line looks better, but as far as SOUND, the Monitor 70's were a better speaker IMO. -
Yes, I gave my set up a lot of thought. Do i want 7.1,6.1,5.1..The 6.1 does it for my size room. I originally bought the polk rm speakers.There was nothing wrong with the rm, after 6 months i replaced with the M . The 505 sub really made the difference.Marantz SR 7007
polkaudio RTi10
polkaudio CSi A6
polkaudio RTiA3
Vizio P65-C1
Universal Remote
Thanks for the input guys. Looks like I'll be getting the monitors. 70's up front and probably 40's for the rear.
Sub wise I can get my hands on a Klipsch KSW-12 (cheap), or should I get a Polk sub?.
Thanks again. -
I think you can get whatever sub you like - as long as you think it's big enough for your room. Looks like power-wise it's 105w FTC & 440w dynamic (which tends to be realistic for subs), so look good. If you do want to get a Polk sub, the PSW-505 is another 12" that is a great bang for the buck - usually can be found for ~$250 or less.Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
