Monitor 11T's
NeilGabriel
We had a discussion concerning these some time ago (but I can't find it).
Anyone own/ed these? Pics? Thoughts? Anyone have specs for them?
1 sl2000 tweets
2 6 1/2 mids
2 8 passives
I did find a 2004 thread where Doro, F1 and others described the speaker as an RTA 11T....so, I will check that in the vintage files....
1 sl2000 tweets
2 6 1/2 mids
2 8 passives
Post edited by NeilGabriel on
http://www.polksda.com/rta11t.shtml
These were my second pair of Polks,, really nice with small tube amps too,,pretty good soundstage and imaging--they will surprise you.JC approves....he told me so. (F-1 nut) -
My first set of polks i bought were 11t's liked them so much bought a second pairMusic doesn't lie. If there is something to be changed in this world, then it can only happen through music.
-Jimi Hendrix -
I didn't like mine at first, but it turned out that I wasn't giving them enough power. They are nominally 6 ohms and the bass seems to only really come alive when the speakers are really manhandled by some wattage, so make sure you have a source that is up to the task.
Aside from that, I feel that they are a tiny bit congested sounding in the midbass, but I do not have them placed optimally. They will certainly play loud and fairly deep - I make guests to my house beg me to turn it down regularly.
Monitor 7s sound a little sweeter to my ears in some way I can't describe, but the 11Ts are clearly superior in enough ways that I use them as my primary loudspeakers. I am running RDO tweeters, but I think the SL2000s sound pretty good in the 11Ts relative to the 7s. I don't know if that's a function of the D'Appolito array design or if it's because the shrill tweeter is balanced by a meatier low end. -
Great speaker.
I used mine for HT and 2ch duty.
I sold them but i still get visitation rights
Refine you search and you will get more hits
http://www.polkaudio.com/forums/search.php?searchid=16479584
PaulyLife without music would♭ -
I got a pair from a friend quite a few years ago. The cabinets where completely thrashed, so I built new ones of exact dimensions. I thought they sounded terrific, and used them for a year or so. When my daughter moved out she needed music so I set her up with a stereo system and these speakers went with it, and to this day she still uses and loves them.HT: Polk SDA SRS 2.3 main fronts, Klipsch RC-25 center channel, Polk RTi-150 rears, M&K V1B sub, Denon AVR-5800, Samsung 52" LCD, Sony BDP-S550
2 Channel: Carver ALS Platinum, Audio Research LS-2B preamp, Counterpoint SA-100 amplifier, Integra CD player, Denon SL7D tt, TC750 phono pre, Nikko tuner
