TSI vs Monitor series sound question
Hedco
Hedco Posts: 32
edited October 2010 in Speakers
I'm sure this has been asked. My search skills are lacking so I appologize for asking a question that has been gone over before.
How much (if any) sound difference is there between these two series of speakers? Tsi vs Monitor.
Thinking about getting M60 or 70's, or Tsi 400 or 500's. Monitor series is cheaper, so if not that much of a difference I'll save some coin and get those.
Thanks.
Post edited by Hedco on
    EndersShadow Posts: 17,703
    edited October 2010
    Hedco wrote: »
    Thanks.
    The Monitor series was replaced by the TSi series in early 09 I believe. The TSi do sound a little different (I have been told, never heard it but whatever). Save the coin go with the Monitor stuff and drop the extra into a really nice sub.
  • B Run
    B Run Posts: 1,888
    edited October 2010
    There's not too much difference, i'd go Monitor for the price.
  • PrazVT
    PrazVT Posts: 1,607
    edited October 2010
    +1 for the Monitors. Even with my A7s, the Monitor 70s look very attractive for the $$.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
  • B Run
    B Run Posts: 1,888
    edited October 2010
    I was happy with my Monitor 60's, I know the 70's will sound even better.
  • over50
    over50 Posts: 201
    edited October 2010
    same here, go with the monitors
    Marantz SR 7007
    polkaudio RTi10
    polkaudio CSi A6
    polkaudio RTiA3
    B&K ST.3140 Power Amplifier
    HSU Research VTF2 MK3
    Vizio P65-C1
    Panasonic 605 blu ray
    Onkyo DS-A4 i-pod Dock
    Universal Remote
    BDI Icon 9429 TV Stand
  • K-daugh
    K-daugh Posts: 467
    edited October 2010
    i own monitor 60s and 30s ......absolutely love them !!!!!!
    Budget 5.1 H.T. Set Up
    HK avr 247 - Adcom GFA-7605:mrgreen::mrgreen: - Belkin PF60 Power Conditioner - Cs2 center channel - Monitor 60's fronts - Monitor 30's rears
    Mirage Bps 150i powered sub - 40"Samsung LCD ln40c530 - Sony Blu Ray Player BDP-S370 - Comcast digital hd box(motorola dcx3400)
    Monoprice Premium Interconnects Monoprice Ultra Slim HDMI w/Redmere:mrgreen: -Knukonceptz Kord 10 Gauge Speaker Wire - Nakamichi Banana Plugs
    Custom Jumpers
  • K-daugh
    K-daugh Posts: 467
    edited October 2010
    over50 wrote: »
    i like your setup how do you like the 40's does 6.1 work for you .....whats it like
    Custom Jumpers
  • dwd999
    dwd999 Posts: 8
    edited October 2010
    You might hear a little difference at the low end since the Monitors have their port on the front and the TSIs have their port on the bottom.
  • Upstatemax
    Upstatemax Posts: 2,735
    edited October 2010
    Go with the Monitors...
    I tested my Monitor 70's back to back with the TSi 500's and I PREFER the Monitor series.
    The TSi line looks better, but as far as SOUND, the Monitor 70's were a better speaker IMO.
  • over50
    over50 Posts: 201
    edited October 2010
    K-daugh wrote: »
    Yes, I gave my set up a lot of thought. Do i want 7.1,6.1,5.1..The 6.1 does it for my size room. I originally bought the polk rm speakers.There was nothing wrong with the rm, after 6 months i replaced with the M . The 505 sub really made the difference.
    Marantz SR 7007
    polkaudio RTi10
    polkaudio CSi A6
    polkaudio RTiA3
    Vizio P65-C1
    Universal Remote
  • Hedco
    Hedco Posts: 32
    edited October 2010
    Thanks for the input guys. Looks like I'll be getting the monitors. 70's up front and probably 40's for the rear.
    Sub wise I can get my hands on a Klipsch KSW-12 (cheap), or should I get a Polk sub?.
    Thanks again.
  • PrazVT
    PrazVT Posts: 1,607
    edited October 2010
    I think you can get whatever sub you like - as long as you think it's big enough for your room. Looks like power-wise it's 105w FTC & 440w dynamic (which tends to be realistic for subs), so look good. If you do want to get a Polk sub, the PSW-505 is another 12" that is a great bang for the buck - usually can be found for ~$250 or less.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
