Swithcing over from Linksys WRT54GS to Apple Airport Extreme
polkatese
Well, after 5 years of pretty reliable connectivity, with the last 2 years of having to reset and power-cycling often, I am trying Airport Extreme. Most feedback has been pretty positive on its reliability, albeit on the pricy side.
Any thoughts on its streaming reliability? It will be supporting 1 WIN7 desktop, 2 WIN7 laptops, 1 macbook Pro, 2 iPhones, 1 DirecTV HD-DVR, XBOX360, Oppop 83, iTunes Airport Express, along with a Linksys modded-client.
I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
Post edited by polkatese on
I've been running one now for several months without a problem of any kind. Using PC not Mac.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
I recently upgraded my trusty Linksys WRT54GS to a Netgear dual-range N band wireless router and I am getting much better performance with streaming video to my Roku boxes and audio to my SqueezeBox Touch(s). I'll get a nother slight bump in performance when I get time to install my new cable modem that can take advantage of the changes in my cable internet feed.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
Airport Extreme has a solid performance. I have used it for more than a year without any problems. Stay away from the Airport Express. Already replaced two times on warranty. They just die!HT/2 CH
McIntosh MX120, MC500, MC206, MEN220
polkaudio SDA SRS 1.2TL, XO, Inductor, Tweeter, Larry's rings, WBT Binding posts, Moretite and Dynamat mod. Built by Mollie Jones 27:th of February 1991, CS350-LS XO mod, LS-f/x, DSW MicroPro 4000
MIT Shotgun S3.3 Bi-wire SC, Shotgun S3.3 SC, Shotgun S3.3 Proline IC, Shotgun S3.3 IC, Shotgun S3.3 Sub cable, AVT 1 Optical IC, EXP 3 Speaker interconnect. -
interesting note on Airport Express. Mine has been online with no problem for a year now, to stream iTunes from my MBP to the Pre/Pro.I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie. -
I have owned a few Airport express units and I don't use them anymore. I never had any issues with them. I use to use them to extend my wireless network hard wired as a WAP and they work excellent and give good coverage. I use a Apple Airport Extreme and it's the best router I have ever owned. Never once had to power cycle it. It's been going for over 3 years.
In the field I use them all the time. They are trusty and steam perfectly. They are designed for high network traffic. They also have a "Guest Network" which is very nice for when people come over and they want to use your network , this gives them a route without having to see anything one your local network.
They are not priced high , actually they are a deal. Most good routers start over 100 bucks and get better as you go up. You get exactly what you pay for in routers.Dan
I would say whatever router you get make sure it's compatible with one of the third party firmwares like dd-wrt or tomato. I'd also like to add that the linksys routers mentioned in this tread with dd-wrt installed are amazing, I have two and I use them as bridges no streaming or gaming problems what so ever.****Home Theater****
Integra DHC-40.1
Rotel RMB-1075
Fronts 265-RT
Center 265-RT
Rears 65-RT
Sub BIC H-100
****VIDEO****
Projector Epson 8700 UB
BLU-RAY Sony BDP-S1000ES
****2-Channel****
Magnepan SMGa
Sub ED A3-250
AMC 3100a
TT Music Hall 2.2
Bellari VP 130 Phono Pre
Grant Fidelity Tube DAC-09
Sirius Stiletto 2 -
DD WRT on the Linksys 54g router runs great
I do have one Linksys dd-wrt repeater that I set up in the entertainment center area for firmware update, and working fine currently. Do I expect problem when I replace the main WRT54GS with Airport Extreme?
thanks in advanceI am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie. -
I doubt you 'll have an issue. I currently use 5 DD-WRT WRT54Gs V2,3,4 in my house. I also have a netgear-n 270mbps attached to the main router for high(er) speed access as well.
All running dd-wrt and bridged if necessary. Great stuff...very stable.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
ok. thanks nguyendotI am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
sir_lagzalot wrote: »I would say whatever router you get make sure it's compatible with one of the third party firmwares like dd-wrt or tomato. I'd also like to add that the linksys routers mentioned in this tread with dd-wrt installed are amazing, I have two and I use them as bridges no streaming or gaming problems what so ever.
I 2nd this2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
