Swithcing over from Linksys WRT54GS to Apple Airport Extreme
polkatese
polkatese Posts: 6,767
edited October 2010 in Electronics
Well, after 5 years of pretty reliable connectivity, with the last 2 years of having to reset and power-cycling often, I am trying Airport Extreme. Most feedback has been pretty positive on its reliability, albeit on the pricy side.
Any thoughts on its streaming reliability? It will be supporting 1 WIN7 desktop, 2 WIN7 laptops, 1 macbook Pro, 2 iPhones, 1 DirecTV HD-DVR, XBOX360, Oppop 83, iTunes Airport Express, along with a Linksys modded-client.
I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
Post edited by polkatese on
  • Fongolio
    Fongolio Posts: 3,516
    edited October 2010
    I've been running one now for several months without a problem of any kind. Using PC not Mac.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • dkg999
    dkg999 Posts: 5,647
    edited October 2010
    I recently upgraded my trusty Linksys WRT54GS to a Netgear dual-range N band wireless router and I am getting much better performance with streaming video to my Roku boxes and audio to my SqueezeBox Touch(s). I'll get a nother slight bump in performance when I get time to install my new cable modem that can take advantage of the changes in my cable internet feed.
    DKG999
  • Janne
    Janne Posts: 139
    edited October 2010
    Airport Extreme has a solid performance. I have used it for more than a year without any problems. Stay away from the Airport Express. Already replaced two times on warranty. They just die!
    HT/2 CH
    McIntosh MX120, MC500, MC206, MEN220
    polkaudio SDA SRS 1.2TL, XO, Inductor, Tweeter, Larry's rings, WBT Binding posts, Moretite and Dynamat mod. Built by Mollie Jones 27:th of February 1991, CS350-LS XO mod, LS-f/x, DSW MicroPro 4000
    MIT Shotgun S3.3 Bi-wire SC, Shotgun S3.3 SC, Shotgun S3.3 Proline IC, Shotgun S3.3 IC, Shotgun S3.3 Sub cable, AVT 1 Optical IC, EXP 3 Speaker interconnect.
  • polkatese
    edited October 2010
    Janne wrote: »
    interesting note on Airport Express. Mine has been online with no problem for a year now, to stream iTunes from my MBP to the Pre/Pro.
  • mantis
    mantis Posts: 17,561
    edited October 2010
    polkatese wrote: »
    I have owned a few Airport express units and I don't use them anymore. I never had any issues with them. I use to use them to extend my wireless network hard wired as a WAP and they work excellent and give good coverage. I use a Apple Airport Extreme and it's the best router I have ever owned. Never once had to power cycle it. It's been going for over 3 years.
    In the field I use them all the time. They are trusty and steam perfectly. They are designed for high network traffic. They also have a "Guest Network" which is very nice for when people come over and they want to use your network , this gives them a route without having to see anything one your local network.
    They are not priced high , actually they are a deal. Most good routers start over 100 bucks and get better as you go up. You get exactly what you pay for in routers.
    Dan
  • sir_lagzalot
    sir_lagzalot Posts: 258
    edited October 2010
    I would say whatever router you get make sure it's compatible with one of the third party firmwares like dd-wrt or tomato. I'd also like to add that the linksys routers mentioned in this tread with dd-wrt installed are amazing, I have two and I use them as bridges no streaming or gaming problems what so ever.
    ****Home Theater****
    Integra DHC-40.1
    Rotel RMB-1075
    Fronts 265-RT
    Center 265-RT
    Rears 65-RT
    Sub BIC H-100
    ****VIDEO****
    Projector Epson 8700 UB
    BLU-RAY Sony BDP-S1000ES
    ****2-Channel****
    Magnepan SMGa
    Sub ED A3-250
    AMC 3100a
    TT Music Hall 2.2
    Bellari VP 130 Phono Pre
    Grant Fidelity Tube DAC-09
    Sirius Stiletto 2
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited October 2010
    DD WRT on the Linksys 54g router runs great
  • polkatese
    edited October 2010
    I do have one Linksys dd-wrt repeater that I set up in the entertainment center area for firmware update, and working fine currently. Do I expect problem when I replace the main WRT54GS with Airport Extreme?
    thanks in advance
  • nguyendot
    nguyendot Posts: 3,594
    edited October 2010
    I doubt you 'll have an issue. I currently use 5 DD-WRT WRT54Gs V2,3,4 in my house. I also have a netgear-n 270mbps attached to the main router for high(er) speed access as well.
    All running dd-wrt and bridged if necessary. Great stuff...very stable.
    Main Surround -
  • polkatese
    edited October 2010
    ok. thanks nguyendot
    txcoastal1 Posts: 13,519
    edited October 2010
    I 2nd this
