Rt5 problem
mikeg
mikeg Posts: 2
edited January 2004 in Troubleshooting
I purchased my RT5's about five years ago and have always used them for rear channel sound. Just yesterday, (1/2/2004), I installed them in a simple stereo setup for my aunt. Now that they are the ONLY speakers, a noticed that one of them sounds "hoarse". That's the best way to describe it. It's as though there is a short somewhere inside the speaker. The sound is crackly & rough....seems to clear a bit at higher volume. I checked the receiver using a different set of speakers and it is NOT the receiver.
What should I do?
Post edited by mikeg on
  • Frank Z
    Frank Z Posts: 5,860
    edited January 2004
    Gently push the drivers in and see if you notice any friction, possibly a scratching noise. If so, the driver is shot. Have you tried swapping the speakers and seeing if the problem is the speaker or the Left/Right channel itself?
  • mikeg
    mikeg Posts: 2
    edited January 2004
    Yes I did switch the speakers from left to right and that did not help. I will try your other suggestion about gently pushing the drivers.
    Thank you :)
    VR3 Posts: 29,394
    edited January 2004
    WTF is all this about? Not to be off topic....but ever since i have bought a pair of the RT5.......All I've read are problems with them! EFFFFFFFFFFFFFFFFFF!
    Good luck with the problem, might be a blown woofer or on its way there.
    Hey, just a thought......
    IT COULD BE a lose crossover piece. Open the problem causing speaker up and give a look...my RT35i had a similair problem a while back. Just a thought of course.....
