New Droid X
  • TNRabbit
    TNRabbit Posts: 2,168
    edited September 2010
    mole' wrote: »
    i have never used the task killer. whats it do?
    metal Detector is fun. there is a heart rate one too. have you guys used the caller ID faker yet? you can call people and have the caller ID # on their cell appear as any # you want. you can change your voice as well.
    Advanced Task Killer lets you individually stop any apps running on your phone. It saves battery--it's hard to tell what's running in the background without it.
    Caller ID Faker sounds fun~
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    Pre installed stuff can not be uninstalled.
    Also you might want to google app killers, they are not recommended and as of the 2.2 updated mine was **** up my phone after about 4 weeks of having it. Once I deleted it everything smoothed back out. The 2.2 upgrade looks to see if a app was improperly shutdown and restarts it so the app killer is not worth messing with anymore. Even when you go into the settings and change the kill type.
    Just a recommendation
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • ken brydson
    ken brydson Posts: 9,003
    Has anyone figured out how to synch Outlook calendar and contacts from Outlook with the Droid X? Apparently there isn't a native app to do so like there is with the BB...
  • thsmith
    thsmith Posts: 6,082
    I went to settings, selected accounts then new accounts and used corporate sync to set mine up with work. Calender, email and contacts all came across.
    I am bummed about the email. No way to cut and paste that I can find. Coming from BB this is required.
  • TNRabbit
    edited October 2010
    Still loving it, but it dropped ALL my Yahoo emails today....??
    TNRabbit
    Sunfire TG-IV
  • Serendipity
    Serendipity Posts: 6,975
    edited October 2010
    I feel like a caveman with my ancient phone :(
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
